20 Most Recent Canon imageRUNNER 6000 Copier Questions & Answers
Your error code is for the fixing unit solve by checking the follwoing:-
1. Fixing lamp.
2. thermistor
3. Fixing assembly if receiving PD
5. if no Potential difference received they the power supply is not okey.
Canon... | Answered on Jun 10, 2019
e001 is a fuser error. it might be able to be reset, but should be looked by a tech.
SERVICE MODE
*28*-press the additional func button, 2&8 at the same time, and the additional func button again.
when you have done it correctly, the screen will change and it will say service mode across the top.
Then select:
copier
func
clear
err
press the done or ok button on the lower right side of the screen.
turn the machine off at the black switch on the right side, wait 10secs, turn back on. should work.
****DONT MESS WITH ANYTHING ELSE IN SERVICE MODE YOU CAN REALLY SCREW UP THE MACHINE.!!!!!!!!!!!!!!!******************
Canon... | Answered on Apr 21, 2019
firmware ir5000
Canon... | Answered on Jan 15, 2019
The scanning lamp (xenon tube) is faulty. The inverter PCB is faulty. The CCD/AP PCB is faulty. The reader controller PCB is faulty.
A specific signal level cannot be attained by CCD gain correction at power-on.
Canon... | Answered on Jan 09, 2018
I believe under the aditional funcation screen, you can calibrate the touch screen. Is the screen working at all? Does it look like there is Water on it and you can not wipe it OFF. If so, the display screen is cracked and needs to be replaced.
Canon... | Answered on May 05, 2016
Hello friend, I have downloaded a Good canon iR2318 service manual from below link:
Canon iR 2318 2320 2420 2422 service manual:
http://goo.gl/dBXTt0
Good luck on repairs.
Canon... | Answered on Sep 02, 2015
The error code means that the finisher bins could not find HP. The problem shows up when something is placed under the bins and stops them from moving down, most of the time a "G" file or a case of paper. Move the object and move the bottom bin up till you hear it click. Before doing that make sure the MAIN Power Switch is OFF on the right side of copier... Then turn the copier back ON and it should clear it self.. Good Luck
Canon... | Answered on Apr 13, 2015
Dear
1) Turn off and then on the main power switch. Is the problem corrected?
YES: Check the operation once again; if normal, end the work.
Check Connectors, DC controller PCB
2) Is the connection of the connector (J1015) on the main controller
PCB and the connector (J122) on the DC controller PCB normal?
Further, is the cable between these connectors normal?
NO: Correct the connectors/cable.
YES: Replace the DC controller PCB.
Thanks.
Canon... | Answered on Feb 07, 2015
149 questions posted
Clive
Clive
old marine
old marine
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
error e000001 0000
  • Office Equipment & Supplies
