20 Most Recent
Canon NP 7130 Black and White Copier Questions & Answers
Canon NP 7130 F copier
Copies
Enter in service mode and do an cartridge adjustment. Maybe the toner is not uniformly distributed in cartridge. Also you can search on internet for service manual, this may help you a lot.
All the best !
Will not copy.
If its giving blank copies there was a ploblem with the laser shutter on these. If so it needs to be taken to authorized Canon repair facility for repair. Maybe still under warranty.
How do I change the drum to a Canon NP 7130 Black and White copier?
Could be the drum or the fuser causing your problem. To replace drum you need to open the machine by hitting the gray release latch on eft ide of machine to clamshell it open. Inside you will see th toner cartridge/ dv unit on the far right and immediately to the eft of that is the drum unit. You need to release the dv unit by turning a lever before removing the drum unit. Should probably call a tech to do this for you so you dont scratch or damage the drum. Drum life on that model is about 30,000 prints. Whats the meter reading on that copier?
Error261 in canon copier
E261
0000 The intervals of zero-cross signals deviate from the tolerance range while
the fixing heater is supplied with power.
Main cause The wiring is faulty (short circuit, open circuit). The main power supply
PCB is faulty. The DC controller PCB is faulty.
Making Corrections
1. Connectors
Are the connector J205 on the main power supply PCB and the connector
J308B on the DC controller PCB securely connected? (zero-cross signal:
J205-7 <-> J308B-1)
NO: Connect the connectors securely.
2. Main power supply PCB, Main controller PCB
Try replacing the main power supply PCB. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
