20 Most Recent Lexicon MC-1 Amplifier Questions & Answers
Hi Hansjo. You may find that if one capacitor has failed, then there may be more. If you see any signs of bulging, leaking, or pushing the bottom out of any caps, then It is a good idea to just change them all. For the small expense, it is worthwhile knowing that your power supply has fresh caps. Try the amp and then see how it goes. If you still have problems, get back to me here and we can talk about it more.
regards
Graeme
Lexicon MC-1... | Answered on Feb 25, 2014
As far as I know, Lexicon schematics are only available to authorized service centers. Can you describe the problem that you are having? Perhaps we can assist you with the repair?
Dan
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Lexicon MC-1... | Answered on Sep 21, 2011
Try :
csupport (at) harman (dot) com
Theyre very helpful
I used to work there.
Lexicon MC-1... | Answered on Oct 09, 2010
HI DannyPara
If the problems are intermittent, then the amp will most probably be suffering from dry solder joints. This is not uncommon about power devices in the unit like output stages and power regulators. I suggest that the amp needs to be checked over for such problems, and where needed resoldered to bring it back to a reliable state. If you are a gun with a soldering iron, you could do it your self. For this sort of work, I prefer to use solder with a 2% silver content as it produces a mechanically stronger soldered joint, and has a higher resistance to failure from the rigours of heating and cooling that constantly happens in amplifiers. If you think you dont have the skills required(good quality soldering is an practiced, and aquired skill), then get it into a decent repair guy for some attention. If you dont fix these problems,new faults may manifest themselves, and even expensive failures to output stages if left unattended.
Happy to answer any other questions you may have about it, just give me a hoy :) Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Lexicon MC-1... | Answered on Jun 02, 2008
replace your hdmi cable between tv and preamp...lemme know if it works.
Lexicon Audio... | Answered on Mar 24, 2014
If you did not backup your iphone with iTunes or iCloud , the recovery software for iPhone users may help you retrieve the deleted data, you can get them back in few steps.
Tips to Retrieve Deleted Voice Memos on iPhone 6 5S
Audio Players &... | Answered 19 minutes ago
After connecting one, turn on the other. Then while both are powered on? Press and hold the button on both earbuds until they connect to one another.
Audio Players &... | Answered 10 hours ago
Lexicon MC-1 Amplifier Logo
19 questions posted
Top Lexicon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Lexicon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Lexicon Audio Players & Recorders
Most Popular Question
volume started fade
  • Audio Players & Recorders
