20 Most Recent
Canon F-710 Calculator Questions & Answers
Sin degrees
Press the "DRG" key (top row, next to the "2nd" key) to cycle through Degrees, Radians, and Grads.
How to remove the grad mode from my canon f-710?
Grad is a unit of angle. The angle unit affects only the results that involve trigonometric functions and their inverses. It cannot affect the display of results in exponential format (scientific). Change the angle unit to degree or radian if you want.Disable the scientific or engineering displays by using FIX or Normal (floating).
My calculator is always in
Hi nolski,
Have a nice day.
Listed below are the ways to set your calculator from scientific to normal mode.
1.Clear your calculator of the last equation you did by pressing the "Clear" button.
2.Click the "Mode" button and use the arrow keys to scroll over "Normal" mode. This will set the calculator up to do basic equations versus any long algebraic equations, or other types of equations on which your were previously working.
3.Practice setting the mode to normal when your are done using your calculator so you always know what mode the calculator will be on when you turn it on next time.
You can follow also this link for fast easy and reliable practices about calculator
http://www.meditec.zeiss.com/iolmaster-online
Hope it helps
Thank you for using fixya.
