20 Most Recent
Bogen Communication Bogen Manfrotto 3265 Grip Action Ball Head with Quick Release Plate Tripod Questions & Answers
It is constantly loose will turn easily without
The normal tightness adjustment is black and on both sides of the handle. There is a plus and minus sign above it on the left side of the grip to show how to get more and less tightness. There is a SECOND adjustment that I just found on the back side of the handle (opposite side from the gray grip on the front). This one requires a very small allen wrench to tighten (clockwise). I assume that this one was designed as the rough adjustment and the upper one is supposed to be for fine tuning during a photo shoot or normal use.Either way, I'm glad I don't have to replace my tripod head. She's been halfway across the world with me!
9/10/2012 5:54:02 PM •
Bogen...
Answered
on Sep 10, 2012
Need bottom section for 2 Bogen3218 monopods any
Individual parts (and the parts list) are availble from Bogen-
http://www.bogenimaging.us/Jahia/site/bius/cache/off/pid/14084
You can get the parts list from:
http://www.manfrotto.com/Jahia/spareparts/site/manfrotto/cache/offonce
but the "search" doesn't seem to work when you put in the code (3218), so you may have to scroll thru the 1300 docs til you get to yours- are you sure it's a 3218- they don't show one, but they show a 3216
8/25/2009 10:08:08 AM •
Bogen...
Answered
on Aug 25, 2009
Leg clamp tightening adjustment on a 055 tripod
There should be a nut on the other side of the housing of the tightening lever that you can tighten. Turn the lever to unlock the leg then start with 1/8 th turns of the nut to tighten, then turn the lever to lock the leg. Do this until you get the desired locking.
3/20/2009 6:04:09 PM •
Bogen...
Answered
on Mar 20, 2009
I tried to use a 16GB PNYcard in my picture fram and it would not work. It said "No Card" on the screen. What's the answer?
If your picture frame is not recognizing the 16GB PNY card and displaying a "No Card" message, there could be several reasons for this issue:
- Compatibility: Some picture frames may have limitations on the size or type of memory card they can accept. Ensure that the picture frame is compatible with SDHC or SDXC cards, as these are the types commonly used for higher-capacity cards like 16GB.
- File System: Check if the memory card is formatted in a compatible file system such as FAT32 or exFAT. Some picture frames may not recognize cards formatted in other file systems. You may need to format the card using a compatible file system on your computer before using it in the picture frame.
- Card Reader Slot: Ensure that the memory card is inserted correctly into the card reader slot of the picture frame. Sometimes, improper insertion can prevent the device from detecting the card.
- Card Compatibility: While SDHC and SDXC cards are generally backward-compatible with devices that support SD cards, some older picture frames may have limited compatibility with higher-capacity SD cards. Try using a lower-capacity SD card (e.g., 2GB or 4GB) to see if the picture frame recognizes it.
- Faulty Card or Picture Frame: If none of the above solutions work, there may be an issue with either the memory card or the picture frame itself. Try using the memory card in a different device to check if it's functioning correctly. Similarly, try using a different memory card in the picture frame to see if it's able to recognize it. If the problem persists, there may be a hardware issue with either the card or the picture frame, and you may need to contact the manufacturer for assistance or consider replacing the faulty component.
By following these troubleshooting steps, you should be able to determine the cause of the issue and resolve it accordingly.
3/16/2024 9:30:07 AM •
Photography
Answered
2 days ago
Need OptiPix Pro software
I own the OptiPix DPF and here is a pic of the owners manual with directions for the OptPixsetup file.
11/25/2023 1:11:02 AM •
Photography
Answered
on Nov 25, 2023
