Casio XJ-350 Multimedia Projector
Problems with Casio XJ-350 Multimedia Projector?
Troubleshooting and Support
Solved Problems for Casio XJ-350 Multimedia Projector RSS Feed Post a New Problem
sharp digital multi media projector PG...
Screen show keeps cutting out for 5 - 20 secs although the projector is still operating and somes back on...
1 Solution
Sanyo Projector==No signal
Sanyo projector is not registering a signal when connected to a Dell laptop. I followed set-up procedure--first,...
1 Solution
vt45 projector turns off without notice.
The projector turns off while in use. It doesn't really needto be "too hot". It may be in the first few...
1 Solution
Remote control for Canon LV X6 Projector
I cannot seem to get the remote control to work for the projector. I'm trying to use a PowerPoint Presentation and the...
1 Solution
user manual
hi i have this new beetel walk clip caller id cordless phone but i do not have the users manual,so i cannot load the...
1 Solution
InFoucus LP500 Projector
My InFocus LP500 projector has a pinkest image when connected to the Dell C840 laptop. I have update the display driver...
1 Solution
SMALL ICON APPEARS ON THE SCREEN (TOP...
USUNG A TOSHIBA PROJECTOR MODEL TLP X3000 AND WHEN WE USE THE REMOTE TO MAKE THE PROJECTORED IMAGE LARGER A SMALL X IN...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
PlatformPC · Mac
TypeDLP Projector
Form FactorPortable
Display TechnologyDLP
Image Brightness2200 ANSI lumens
Contrast Ratio1000:1
Max Resolution (Native)1024 x 768
Image Aspect Ratio4:3 (Standard)
Image Size (Diagonal)15 in. - 300 in.
Screen Distance2.63 ft. - 17.5 ft.
Color Support24-bit (16.7M colors)
Max Resolution (Interpolated)1600 x 1200 (UXGA)
Synchronization Range Horizontal15 - 92 kHz
Synchronization Range Vertical50 - 85 Hz
Technical Features
Audio OutputSpeaker(s)
Operation Noise37 dB
Front Panel ControlsKeypad
Remote Control FeaturesBuilt-in Mouse
Interfaces
InterfaceUSB
Video Input15 Pin D-Sub VGA · 4 Pin - Mini DIN (S-Video) · Composite Video
Lamp
Lamp TypeHigh-Pressure Mercury
Light Source Life2000 Hours
Light Source Power200W High-Pressure Mercury
Other Features
Special FeaturesKeystone Correction · Invert Image · Picture in Picture
Speakers Output1 W
Projection MethodRear · Front
Standards
Analog Video FormatNTSC · PAL · PAL-M · PAL-N · SECAM · PAL 60
HDTV Formats720p · 1080i · 480p · 576p · 480i · 576i
Warranty
Warranty3 Years
Dimensions
Depth6.7 in.
Height2.2 in.
Width9.1 in.
Weight3.97 lb.
Casio Contact Information
Main support number800-962-2746
Sponsored Links
Loading problems.
Top Experts
Ask Me
Noggin Guru
1 solutions
Ask Me
Marrie Wiz
15 solutions
Ask Me
Benimur Guru
3 solutions
Repair Service
Find Multimedia Pro. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
