FixYa.com
Casio XJ-560 Multimedia Projector
All Products > Casio > Multimedia Projectors
Problems with Casio XJ-560 Multimedia Projector?
Search inside Casio XJ-560 Multimedia Projector Knowledgebase
Troubleshooting and Support
Solved Problems for Casio XJ-560 Multimedia Projector RSS Feed Post a New Problem
How do I redirect the output of my PC...
How do I redirect the output of my PC laptop to the projector?
1 Solution
How do I adjust the frequency for an...
How do I adjust the frequency for an external monitor (projector)?
1 Solution
my problem is that the Image is not...
my problem is that the Image is not stable, on my projector, any suggestions?
1 Solution
Projection Problem with Toshiba TLP 261
When the projector is turned on, it displays the default screen. In the lower left corner the display is red. Adjusting...
1 Solution
Epson EMP-82e locked out
One of our staff turned off the projectors power. He then proceeded to input the wrong security code and the projector...
1 Solution
Connecting Sky TV to my projector
I am finding it hard to connect my sky tv to my projector, which cable do i need.
2 Solutions
green tint
I just purchased an epson powerlight s1. All the highlights are green. I tried adjusting the color and tint, but nothing...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeDLP Projector
Form FactorPortable
Display TechnologyDLP
Image Brightness3000 ANSI lumens
Contrast Ratio2000:1
Max Resolution (Native)1024 x 768
Image Aspect Ratio4:3 (Standard)
Image Size (Diagonal)15 in. - 300 in.
Screen Distance2.62 ft. - 17.39 ft.
Color Support24-bit (16.7M colors)
Max Resolution (Interpolated)1600 x 1200 (UXGA)
Synchronization Range Horizontal15 - 92 kHz
Synchronization Range Vertical50 - 85 Hz
Technical Features
Audio OutputSpeaker(s) · 3.5 mm Mini Jack
Operation Noise33 dB
Remote Control FeaturesLaser Pointer · Built-in Mouse
Interfaces
InterfaceUSB · Infrared
Video Input15 Pin D-Sub VGA · 4 Pin - Mini DIN (S-Video)
Lamp
Lamp TypeNSH
Light Source Life2000 Hours
Light Source Power270W NSH
Other Features
Special FeaturesKeystone Correction · Picture in Picture · Key Lock · Password Lock
Speakers Output1 W
Projection MethodRear · Front · Ceiling
Standards
Analog Video FormatNTSC · PAL-M · PAL-N · SECAM · PAL 60
Warranty
Warranty3 Years, 90 Days On Lamp
Dimensions
Depth8.43 in.
Height2.52 in.
Width10.94 in.
Weight5.95 lb.
Casio Contact Information
Main support number800-962-2746
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
