FixYa.com
Datalogic Dragon M101  Portable Terminal
All Products > Datalogic > Barcode Scanners
Problems with Datalogic Dragon M101 Portable Terminal?
Search inside Datalogic Dragon M101 Portable Terminal Knowledgebase
Troubleshooting and Support
Solved Problems for Datalogic Dragon M101  Portable Terminal RSS Feed Post a New Problem
lexmark printer drivers
i want to download lexmark X1100 series printer drivers no sirve
1 Solution
i am not able to use my barcode scanner
2 Solutions
distributors requiring isbns when my CDs...
I have been seeking a distributor for my music products, initially three CDs. Because the CDs only have bar codes, is...
1 Solution
BARCODE Generator
Plz. tell me how to code alphabets and numbers in barcode
1 Solution
change region code on my apple mac
I have bought a DVD from Amazon and can't play it because I can't change the regio code on my computer - how do you do...
1 Solution
Optical Drive not working.
Hi! I use a Toshiba Tecra M5 notebook & it has MATSHITA DV RAM optical drive. This device is not working & the...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Datalogic Dragon M101  Portable Terminal RSS Feed Post a New Problem
Datalogic Dragon M101 postamble CR to HT...
I've got a Datalogic Dragon M101 barcode scanner and I need to change the postamble from Carriage Return(CR) to...
Post a Solution
Keyboard Issue
We have an issue where the keyboard on a PC connected via a Datalogic Dragon M101 hand scanner, keeps beeping and...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypePortable Terminal
ConnectivityCordless
Optical
Light Sourcevisible laser diode (VLD)
Scan Rate35 Scans per second
Pitch Angle5
Skew angle60
Technical Features
Special FeaturesPositive Beeper user feedback, Positive Led user feedback, LCD Display, Keypad
CompatibilityPC
Decode CapabilityCode 39, Code 93, ISBT 128, Code 128, CODABAR, Bookland EAN, MSI Plessey, Code 11, MSI, Telepen, UPC/EAN, Code 49, Codablock, Code 32
Environment protectionHumidity: 0% - 90% non condensing
Battery
BatteryRechargeable, Nickel Metal Hydride (NiMH)
Dimensions
Width.75 in.
Weight.75 lb.
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
