20 Most Recent
Nerf N-Strike Longstrike CS-6 Questions & Answers
My nerf nemesis rival is not working
Because I'm unsure what version of the Rival Nemesis you have, I'd contact Hasbro directly and live chat or email their customer support team for troubleshooting advice. I've included the link.
Hope this helps!
4/19/2020 11:21:07 PM •
Nerf Toys
Answered
on Apr 19, 2020
Why does my nerf regulator not work after using 2 3.7 lipos?
Did you verify that the Nerf could handle this type of power prior to using? Hopefully you didn’t fry anything.
If you’ve found this helpful, please click the green “helpful” icon. If you have 20 seconds please leave a few words as a review or recommendation! Also, follow me for more answers to everyday issues, I’m all for saving you money and making the most of your time! Thanks and have a great day!
3/15/2019 10:18:58 AM •
Nerf Toys
Answered
on Mar 15, 2019
Praxis pump slide handle jammed
1. Get a ruler
2. Push the ruler down the barrel so the end is near the bottom of the disc
3. Jiggle the ruler from left to right
4. Shoot the gun/Press the disc eject switch
12/21/2013 11:00:41 PM •
Nerf Toys
Answered
on Dec 21, 2013
Nerf Vulcan won't auto-fire
I had the same problem with two guns out of the box. Turned out that the dividers in the battery tray kept the batteries from touching each other on some brands of batteries. Remove the dividers and should work. You can verify this by measuring the voltage on the two terminals of the battery pack.
11/8/2013 12:39:11 AM •
Nerf Toys
Answered
on Nov 08, 2013
My 8 year old grandson
unscrew the entier gun... all nerf guns are screwed together. you can practically cut the gun in half by unscrewing it. just make sure to put everything back how you found it. good luck to you.
3/29/2011 10:20:53 PM •
Nerf Toys
Answered
on Mar 29, 2011
Hi I've got a babyweaver
Sounds like you are missing the central support rod or bar that connects the Babyweaver swinging crib to the stand, providing stability and support for the crib. This component is crucial for maintaining the structural integrity of the crib and ensuring safe usage. Here are some steps you can take to address the missing part:
1. Contact the Manufacturer:
- Reach out to Babyweaver or the manufacturer of the swinging crib to inquire about obtaining a replacement central support rod.
- Provide them with details about the missing part and the specific model of the swinging crib to ensure you receive the correct component.
2. Check for Spare Parts:
- Check if the swinging crib came with a user manual or assembly instructions that may have information about spare parts or replacement components.
- Look for any contact information provided for customer support or spare parts inquiries.
3. Online Search:
- Conduct an online search using keywords such as "Babyweaver swinging crib central support rod" or "Babyweaver crib replacement parts" to see if you can find the specific part for purchase.
- Explore baby product retailers, online marketplaces, and specialty stores that offer replacement parts for nursery furniture.
4. Local Retailers:
- Visit local baby product stores or furniture stores that carry nursery items.
- Bring the existing part (if you have one side of the support rod) to help them identify and match the missing component.
5. Custom Fabrication:
- If you are unable to find a suitable replacement part, consider contacting a metal fabrication shop or a carpenter who may be able to custom-make a central support rod that fits your Babyweaver swinging crib.
- Provide them with measurements and details about the required specifications for the part.
3/22/2024 3:29:32 AM •
Toys
Answered
on Mar 22, 2024
I have a new model teddy ruxpin and my 2 year old daughter tripped and dropped him. His lights all come on but his app and sound are not working
It sounds like the drop may have caused some internal damage to the electronics or wiring of the Teddy Ruxpin toy. Here are some steps you can take to try and troubleshoot the issue:
- Restart the Toy: Sometimes a simple restart can resolve minor issues. Try turning off the toy completely, including any power switches or buttons, and then turning it back on again after a few moments.
- Check Battery Compartment: Ensure that the batteries are properly inserted and making good contact with the terminals inside the battery compartment. If the drop caused any displacement of the batteries, it might affect the toy's functionality.
- Inspect for Physical Damage: Carefully examine the exterior of the toy for any signs of physical damage, such as cracks, dents, or loose parts. If there's visible damage, it may indicate internal damage as well.
- Test with Different Devices: If the Teddy Ruxpin toy connects to a separate app or device for sound playback, try connecting it to a different device to see if the issue persists. This can help determine if the problem lies with the toy or the connected device.
- Contact Customer Support: If none of the above steps resolve the issue, it's possible that the drop caused internal damage to the toy's electronics or wiring. In this case, you may need to contact the manufacturer's customer support for assistance. They may be able to provide further troubleshooting steps or offer a repair or replacement option.
Keep in mind that since the toy is relatively new, it may still be under warranty, which could cover repairs or replacements for damage caused by accidents like drops. Be sure to check the warranty information or contact the manufacturer for guidance on warranty coverage.
3/21/2024 2:25:15 PM •
Toys
Answered
on Mar 21, 2024
Fisher-Price J7485 T-Rex stopped moving
Check Batteries: Ensure that the batteries are properly inserted and have sufficient charge. Sometimes, a low battery can cause the toy to stop functioning.
Switch On/Off: Confirm that the toy is switched on. Some toys have an on/off switch or button that might accidentally get turned off.
Connections and Wires: Inspect the wires and connections inside the toy. Loose wires or faulty connections can lead to malfunction.
Obstructions: Look for any obstructions or debris that might be preventing the T-Rex's movement. Clear any blockages.
Reset: If there's a reset button, try pressing it. This can sometimes resolve minor issues.
Contact Customer Support: If none of the above steps work, consider reaching out to Fisher-Price customer support as below.
https://service.mattel.com/us/ContactUs.aspx
2/22/2024 2:51:59 PM •
Toys
Answered
on Feb 22, 2024
