FixYa.com
JVC KS-AX6300 Car Audio Amplifier
All Products > JVC > Car Amplifiers
Problems with JVC KS-AX6300 Car Audio Amplifier?
Search inside JVC KS-AX6300 Car Audio Amplifier Knowledgebase
Troubleshooting and Support
Solved Problems for JVC KS-AX6300 Car Audio Amplifier RSS Feed Post a New Problem
Amp power
Should I run the amplifier powered from the receiver or from the battery? Forgive me, I am new to this. Receiver...
13 Solutions
I´ve got 2 amps for my subs,but only...
I´ve got 2 amps for my subs,but only one pre-out from HU of course.i know i should be using amp´s line out to...
1 Solution
Need a power connector for a Boss IQ 3KD.1...
Where can I find a replacement power connector for a Boss IQ 3KD.1 3000W Class D Monoblock Amplifier. The screw loosened...
1 Solution
Amp isn't putting out any sound
My amp just up and quit and now it won't put out any sound. It will power on but that is as far as it gets and the LED...
1 Solution
what ohm load is best?
is the lowest ohm wire configuration gonna get the best sound out of your amp? ive got a 1 ohm stable amp, is that what...
1 Solution
8 Ohm Load? Why?
I was playing with the woofer wiringwizard, and for (2) 4 Ohm subs it shows how to wire it so the amp sees 8 Ohms. i was...
1 Solution
power light
My amps power light does not work, is there anyway I can make it work again?
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Power Output
RMS Power at 4 Ohms.8 W x 50
RMS Power at 2 Ohms1 W x 50
JVC Contact Information
Main support number(800) 252-5722
Email supportproinfo@jvc.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
