20 Most Recent Apple A1136 iPod Classic Video/MP3 Player - 30 GB - 5th Generation - B Questions & Answers
Lost ipod user manual
You can do an online search for a pdf version that you can view from your computer or phone. Do a search for "your model number pdf".
2/2/2015 7:07:34 PM • Apple A1136 iPod... • Answered on Feb 02, 2015
I think the battery is dead inside how do I fix this
Nothing i guesss. Buy new one
9/29/2014 6:46:21 AM • Apple A1136 iPod... • Answered on Sep 29, 2014
2answers
How do I download music from my computer files to my ipod nano
For Apple iPods that are still running their original firmware (not jailbroken) the best and safest way to transfer music and other files onto the device is to use iTunes. You can download iTunes and any tutorials on adding music to your iPod through iTunes at Apple's website. Hope this helps! Apple iTunes Everything you need to be entertained
1/26/2024 5:29:25 PM • Apple iPod Audio... • Answered on Jan 26, 2024
How to figure out my passcode for a a 80gb iPod please?
Question edited for clarity and spelling of 'figure'. Question moved from Audio Players and Recorders. You as the owner who set the code is the only one that can figure it out. Connect it to your computer. Log into iTunes, and do a hard reset on it. That will scrub it clean and reload the operating system. Then you can Restore from back up with no passcode.
2/9/2023 8:26:51 PM • Apple iPod Audio... • Answered on Feb 09, 2023
2answers
Help ineed account for my Ipod please help
Step 1:an itunes account ? b> An iPod is a portable media player that lets users listen to music wherever they are. Before you can listen to songs on the iPod, you must first put music onto the device. If you have been using different MP3 players in the past, adding music to an iPod can be slightly confusing. The reason for this is that iPods are not compatible with Windows Media Player, Real Player or Winamp. By using iTunes, however, you can add music to any iPod. • Open iTunes. • 2 Add music to iTunes. To do this, click "File." Choose "Add Folder to Library." Then, find the folder on your computer that holds the music you wish to put onto the iPod. Highlight that folder and click "OK." The music will be put into the iTunes Library. • • 3 Plug the iPod into the computer. After a few seconds, you will see the iPod listed under "Devices" on the left-hand side of iTunes. • 4 Click "Music" under the "Library" option on the left-hand side of iTunes. All of the music files in the iTunes Library will then be shown in the middle of iTunes. • 5 Double-click the album that contains the music you want to put onto the iPod. The songs on that album will then be listed. • 6 Highlight the song you want to add to the iPod. • 7 Drag that file over to the name of your iPod located under "Devices" (as mentioned in Step 3). The song will then be placed onto the iPod. Do this for all of the music you want to put onto the iPod. • 8 Click the "All Albums" button at the top of iTunes to get back to the list of albums on the iTunes Library. • 9 Repeat Steps 5-7 until you are done putting music on the iPod. • 10 Disconnect the player when you are done.
2/11/2022 4:25:48 AM • Apple iPod Audio... • Answered on Feb 11, 2022
4answers
I can't play or send
i understood your problem ........The best solution is to use Format Factory software to convert your FLAC music file to any music file format like mp3,mp4,aac,mxmmf,midi,wav....etc..
After converting you can able to play music on your i-pod
If you have apple's I-pod then you requires I-tunes Software to sync the music files to your I-pod....
here i am giving you the link of format factory software enjoy....
http://download.cnet.com/FormatFactory/3000-2194_4-11660921.html
Thank you for giving me opportunity to solve your problem.
please give me your Ratings!!
6/17/2021 7:21:38 AM • Apple iPod Audio... • Answered on Jun 17, 2021
What voltage is the ipod 1320
The cell is charged to about 4 or 4.25V. The USB port has a voltage of 5V. Thus the charging voltage should be somewhere between 4.25 and 5V
12/30/2020 12:48:21 PM • Apple iPod Audio... • Answered on Dec 30, 2020
5answers
How to setup VPN on iPod?
connect to WiFi. Tap General>Network>VPN> you can try these settings I've used before: Add VPN Connection. chose PPTP. Give it a name under description. Encryption Level:Auto Send all traffic: ON Proxy: Off RSA SecurID: OFF Here's the part that differs from the VPN I personally set up. Server: enter the IP address of the VPN Server. this is specific to you, as to what server you want. Account: Enter username and password to log in. If this VPN is for school, it would be your school username and school password you normally use. The VPN at my school worked when I connected to their wifi and then turned on the VPN. for added information.
6/15/2020 12:28:44 PM • Apple iPod Audio... • Answered on Jun 15, 2020
4answers
How to fix a iphone is disabled
If your iPhone has been disabled, it is completely locked down. The only way you'll be able to use it again is by restoring it using iTunes or iCloud. If you have a backup, you'll be able to recover your data, but this process will delete everything that is stored on the iPhone. Except for the following four ways, there is no other way to unlock a disabled iPhone. Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted. Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required. Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window. Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPhone. Once the reset process is complete, you'll be taken through the iPod's initial setup process. Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored. reset-iphone-password-with-itunes-hraoc4bd1cy3f24n2aesny2m-3-0_0.jpg For more detail, check: How to Unlock A Disabled iPhone with/without iTunes
2/1/2019 3:49:11 AM • Apple iPod Audio... • Answered on Feb 01, 2019
2answers
IPod third generation 3g won’t connect to 2019 Honda Pilot via USB. Screen indicates Unsupported device.
You are not likely to be able to use it with that vehicle, That version of IPOD is 16 years older than you car. There wont be drivers available for it. You cannot change the car system, you may be able to get an audio jack if the car has AUX in.
12/28/2018 12:29:29 AM • Apple iPod Audio... • Answered on Dec 28, 2018
Apple A1136 iPod Classic Video/MP3 Player - 30 GB - 5th Generation - B Logo
5 questions posted
Popular Products
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
iPod Apple
  • iPod Apple
Most Popular Question
lost ipod user manual
  • Audio Players & Recorders
