20 Most Recent
JVC Sirius KD-G300 CD Player Questions & Answers
My jvc kd-g300 head unit shorts out and comes back
Could it possibly be a loose wire behind ur deck that connects itself when bass starts to hit? Just an idea of a possibility..otherwise check all possible fuses that could be responsible for the loss of power.
JVC KD-G300
Here is a link to the manual:
http://books.jvcservice.com/download/718134980/32506.pdf
There does not appear to be a way to set tuning to european standards. Is there a particular reason you want to be able to tune those frequencies?
Jvc kd g300
Setting the minutes is easy. Hit the SEL button for 2 seconds, and you can set the minutes by turning the knob.
Setting the hours is much harder. I don't know the official way, but I can offer a work-around.
To change the hours backwards (as in daylight savings time in the fall), wait until one minute before the hour (X:59). Then set the minutes to 00 (effectively going back 59 minutes). After a minute (or two), when you are now in the correct hour, set the minutes to the correct minute.
Changing the hours ahead (as in daylight savings time in the spring) is easier. Change the minutes to 59. Wait a minute (until the hour rolls over), and then adjust the minutes back to the proper time.
No power
why didnt you hook it up to your wiring harness and were is the red wire hooked up the yellow is the memory wire make sure you have a good ground
My JVC-SD5 lights up, plays Music, but the lid won't open, any suggestions?
It seems like you're facing a little hiccup with your JVC-SD5. There's some troubleshooting ideas...
Firstly, make sure the CD player is powered off and unplugged from the electrical outlet. Safety first, right?
Now, take a good look around the edges of the CD lid. Sometimes, dust or debris can accumulate and prevent it from opening smoothly. Grab a soft, lint-free cloth and gently wipe the edges of the lid. Make sure to remove any obstacles that might be blocking it.
If that doesn't do the trick, let's try a little trick called the "manual release." Look for a small, pin-sized hole near the CD tray. It's usually located either on the front panel or underneath the CD player. Take a paperclip or a small, pointy object and insert it into that hole. Apply gentle pressure to trigger the manual release mechanism. This should pop open the lid, giving you access to your beloved CDs.
Once the lid is open, inspect the CD tray and the surrounding area for any visible signs of damage or obstructions. If everything looks fine, try closing and reopening the lid a few times to see if it starts functioning properly. Sometimes, a little exercise can go a long way in resolving minor glitches.
I hope these suggestions help you get your JVC-SD5 back in action and free you from that unwanted station! If you have any more questions or need further assistance, feel free to ask. Good luck!
My JVC stereo 6020 not making noise
i kindly recommend that you check volume level is not set to mute.Also,ensure that the stereo is properly connected to the speaker.check if the speaker are working
How to reset the clock on a JVC pc-110 boom box 1994 model?
To reset the clock on a JVC PC-110 boombox from 1994, follow these steps:
- Press the Clock Set button, located on the top of the boombox, to enter clock setting mode.
- Press and hold the Clock Set button until the hour digits on the display start flashing.
- Use the Fast Forward and Rewind buttons to adjust the hour to the correct time.
- Press the Clock Set button again to move to the minute digits. The minute digits will start flashing.
- Use the Fast Forward and Rewind buttons to adjust the minute to the correct time.
- Press the Clock Set button one final time to exit clock setting mode and save the new time.
Your JVC PC-110 boombox should now display the correct time.
