FixYa.com
JVC DRM10 DVD Recorder
All Products > JVC > DVD Players
Problems with JVC DRM10 DVD Recorder?
Troubleshooting and Support
Solved Problems for JVC DRM10 DVD Recorder RSS Feed Post a New Problem
Darn blue loading light won't stop
Hi there, I have a JVC Dr M10 dvd recorder that I used to love until the blue loading light got stuck. I got it unstuck...
2 Solutions
continuous flashing loading
I have a problem with my JVC DVD recoder when you put power on it flsahes LOADING blue for a long time and you cant play...
3 Solutions
Recordable DVD
I have purchased a pack of maxwell DVD-R Discs and the unit says to insert a recordable disc although there is one...
2 Solutions
loading blue light
an suggestion will be welcome. My DVd DMR10 just says loading....
1 Solution
JVC DRM10 DVD Recorder Problem
Hi, I have the following problem with my DVD recorder: any time I turn it on it starts to flash the blue light where you...
3 Solutions
Sound Interference
I keep getting a terrible interefence on the sound through this unit. This will only clear by unplugging the unit,...
1 Solution
DVD light stays constant dim red (orange).
The cyber home dvd when connected to power, does not glow to red, it remains orange and DVD player is not operational....
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for JVC DRM10 DVD Recorder RSS Feed Post a New Problem
Recording digital channels
How do I record digital channels received through my 'set top box'? As the record menu on the DR-M10 doesn't list...
Post a Solution
JVC dvd recorder
I have been given a jvc dvd recorder. model DRM105. serial no 10931430. It does not have any instructions. do you know...
Post a Solution
recording difficulty
During playback of a recording, the disc has stops and starts.
Post a Solution
DR-M10 Replacement Drive
What drive did you use? I've tried various units but none are fully compatable. Thanks.
Post a Solution
Formatting Problem
JVC DRM10 DVD Recorder is giving me an error message that says, "COULD NOT FORMAT THE DISC-CHECK DISC".
Post a Solution
region setting for new drive unit
I've just replaced a faulty drive unit in this dvd recorder.I've now forgotten how to set up the region2 code for...
Post a Solution
region setup for new drive unit
I recently replaced the drive unit in the dr m10 because the old one got 'MASHED' by my friend when the disc got stuck...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
DVD TypeDVD Recorder
Number of Discs1
Progressive ScanWith Progressive Scan
Playable Disk TypesDVD-RAM · CD-RW · CD-R · CD (Audio) · VCD · DVD-RW · SVCD · DVD Video · DVD-R
Playable File FormatsJPEG · MP3
Video
Video DAC10 bit / 54 MHz
Video Noise ReductionBlock Noise Reduction · Hadamard Noise Reduction
Audio
Surround SoundDTS (Digital out only) · Dolby Digital (Digital out only)
Audio DAC24 bit / 192 kHz
Connections
OutputsS-Video x 1, Digital Audio Coaxial x 1, Digital Audio Optical x 1
InputsAnalog Audio x 2 · S-Video x 2 · Composite x 2 · iLINK DV Input
Front PanelComposite Input · Audio Input
Convenience
Remote ControlMultibrand
Record And Play FetauresSimultaneous Record and Play
Instant Skip / Replay7 sec. Replay
OSDYes: English, French, Spanish
Parental ControlYes
Display DimmerYes
Recorder
Recordable MediaDVD-RW · DVD-R · DVD-RAM
Programmable TimerVCR Plus+, 8 Events within 30 Days
Recording SpeedsLP · SP · EP · XP · FR
Dimensions
Depth14.17 in.
Height2.76 in.
Width17.13 in.
Weight13.23 lb.
Other Features
Exterior ColorSilver
Warranty
Warranty90 Days
JVC Contact Information
Main support number(800) 252-5722
Email supportproinfo@jvc.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
