20 Most Recent JVC AV-32F702 32" TV Questions & Answers
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
JVC AV-32F702... | Answered on May 02, 2013
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
JVC AV-32F702... | Answered on Sep 13, 2009
22uf/250v from the 180v flyback output and 100 uf/50v in vertical and the last 220uf/16-25v from 16v line of flyback.
JVC AV-32F702... | Answered on Nov 10, 2008
Is there a simple fix for this, yes The picture is very dark it is mostly due to 1 power supply output is low. 2 voltage on crt g2 pin is low. 3 video output supply is low. 4 some components in luminance section might be defective or loose. 5 finally crt getting weak but as you have bought in 2004 so possibility is rear. good luck
JVC AV-32F702... | Answered on Sep 22, 2007
Unfortunately, there is no easy fix for this. If it were a rear projection TV, I'd suggest a new bulb. Even on a Plasma there are things that can be done. But on a CRT, the repair for a dark screen usually costs more than replacing it.
JVC AV-32F702... | Answered on Sep 20, 2007
Some TV's have tuners that do a better job of rejecting interference than others. Unfortunately, there is not much you can do about it, other than to identify and eliminate the source of interference.
JVC AV-32F702... | Answered on Jun 27, 2007
JVC would be a possible source.
JVC Televison &... | Answered on Sep 17, 2019
it needs service,
or buy the service manual and read.
sound like the power supply inside is bad or the lamps back light.
ask here
http://www.us.jvc.com/support/
JVC Televison &... | Answered on Sep 16, 2019
Troubleshooting page 19, Manual below may provide some help. There are instruction on how to reset on second page
http://www.manualsdir.com/manuals/131334/jvc-kd-s6060.html
JVC Televison &... | Answered on Sep 08, 2019
I've the user manual to your TV. But, I can't send it to you by this window as it does not allow me to upload any PDF files by it. I do not remember, from which site I've downloaded it at about two months ago. If you send your email address to me by Fixya comment, I'll send a copy of it to you by return mail.
JVC Televison &... | Answered on Sep 05, 2019
check the picture board or the back light if all bolbs are well working
JVC Televison &... | Answered on Aug 24, 2019
Hi Grizzly, indicate your JVC TV model and type of remote control you are commenting on, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Grizzly, indica modelo de tu TV JVC y tipo de control remoto del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
JVC Televison &... | Answered on Aug 13, 2019
JVC AV-32F702 32" TV Logo
9 questions posted
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
jvc av 32f702 color tv shuts off after
  • Televison & Video
