Home
My Products
Sign In
All Products
Falcon
Barcode Scanners
Problems with Falcon 335 Portable Terminal?
Add to Warranty Manager
Search inside
Knowledgebase
Troubleshooting and Support
Post a New Problem
"Falcon 335 User Guide"
Need a electronic copy of the "Falcon 335 User Guide"
1 Solution
Problems with BHT scanner
when downloading data to BHT (new lookup) it starts to transfer some information and then stops, and 'File transfer,...
1 Solution
lexmark printer drivers
i want to download lexmark X1100 series printer drivers no sirve
1 Solution
Optical Drive not working.
Hi! I use a Toshiba Tecra M5 notebook & it has MATSHITA DV RAM optical drive. This device is not working & the...
1 Solution
distributors requiring isbns when my CDs...
I have been seeking a distributor for my music products, initially three CDs. Because the CDs only have bar codes, is...
1 Solution
analys of how to connect java application...
hi sir, tell me how the third party tools are connect to java application. my problem is that how to connect the bar...
1 Solution
BARCODE Generator
Plz. tell me how to code alphabets and numbers in barcode
1 Solution
View All
Unsolved Support Problems
Post a New Problem
broken switch
need internal wiring circuit
Post a Solution
ERROR B OPEN DATA
Could you please let me know how to sort out the error mentioned in the subject line. i am getting the error just after...
Post a Solution
Add another loop?
The scanner needs what I've been told as another loop. One of the fields needs to stay in place while scanning until...
Post a Solution
Tips & Tricks
Post a New Tip
Be the first to Post a New Tip
WikiManual
Post a New Chapter
Be the first to Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Be the First to upload Manual or Guide
Specifications
Key Features
Type
Portable Terminal
Interface
RS-232
Connectivity
Cordless
Optical
Light Source
visible laser diode (VLD)
Scan Rate
39 Scans per second
Networking
Wireless Data Comunication
2.4 Ghz Technology
Technical Features
Special Features
Positive Led user feedback, LCD Display, Keypad, Upgradable Flash Memory
Compatibility
PC
Decode Capability
EAN-8, EAN-13, Code 39, Code 39 Full Ascii, Code 93, Code 128, CODABAR, Interleaved 2 of 5, Bookland EAN, MSI Plessey, Standard 2 of 5, UPC (E&A), Code 11, UPC/EAN, Matrix 2 of 5, Codablock
Environment protection
IP 54 (Water and Dust Resistent), Humidity: 5% - 95% non condensing
Battery
Battery
Rechargeable, Nickel Metal Hydride (NiMH)
Dimensions
Depth
1.4 in.
Height
7.8 in.
Width
.8 in.
Weight
.8 lb.
Sponsored Links
Bogda
Let one of our
Experts Solve
your Problem
DO YOU WORK FOR
FALCON
Register as STAFF
Top Experts
bluegreen
New Products
Powered by
Repair Service
Find Barcode Scanner Repairman Near You:
Advertise Here
powered
by
Get this Widget
