20 Most Recent JVC MX-GT88 CD Shelf System Questions & Answers
Chances are that something is blown in the power output stages and units shuts down to protect against further damage.
Repair or replace, which ever is cheaper!
JVC MX-GT88 CD... | Answered on Dec 08, 2015
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/JVC-MX-GT88-manual/id/314bh540/t/2/
Page 32, 7, 8
Ther's also a subwoofer level button on the remote. Page 10
If it has a bi-amp, you can connect the speakers to it. By the amplifier, if it's a stereo with bi-amp, be sure that it has at least 400 watts and up in order for the speakers to turn out great, if a receiver like a integrated amplifier, it may have like 2-10 connections, you can connect the speakers all together if it has more than 3 connections, if below 3, you may need to take the speakers apart and make it 3 way by connecting one wire to the tweeter, another wire from the tweeter to the main or mid speaker then one more wire from the main or mid speaker to the sub.
JVC MX-GT88 CD... | Answered on May 28, 2015
Yes, it probably is.
No.
Sometimes.
Press the correct button - the one on the left and slightly up from the big one.
75W on a good day.
[These are vague answers in response your your equally vague question. Enjoy!]
JVC MX-GT88 CD... | Answered on Oct 20, 2014
I'm assuming the cd door ejects outward if you need a belt. I had this happen to a dvd drive. I simply dis-assembled the top of the drive and removed the tray exposing the sprockets to the assembly that moves the tray in and out. I then replaced the belt with a rubber band and found that it worked out great after re-assembly. Considering it will not spin with the force of a vacume cleaner this should work out.
JVC MX-GT88 CD... | Answered on Nov 08, 2011
One of your negative wires are most likely touching a positive wire. Very common.
JVC MX-GT88 CD... | Answered on Feb 03, 2011
It is most likely an amplifier problem. I had this problem before. It went into "Protect" mode and shut down. When I turned it back on, my left channel speakers made a buzzing noise and did the same thing again. I got it diagnosed at an electronics repair shop and they found that the two STK amplifier IC's were bad. One is about $106 and the second one is about $78. I got it fixed for about $200 and works basically like new again.
I would love to help you.
Please respond by PRESSING REPLY OR COMMENT
Did your electricity recently go out?
Bruce
JVC MX-GT88 CD... | Answered on Jan 13, 2011
use the speakers it came with it works fine for me i have mine hooked up to a 300w inverter anything less i dont get the best sound you cant turn the volume up too loud on the reciever it will draw too much power and shut it off or blow the fuse in you car unless the inverter you are using has an external fuse on it my inverter warns me that i am drawing to much power so when i hear the beep i turn it down a notch and works fine but ya try using the speakers th system came with
JVC MX-GT88 CD... | Answered on Feb 25, 2010
JVC MX-GT88 CD Shelf System Logo
41 questions posted
Popular Products
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Audio Players & Recorders
Most Popular Question
protected
  • Audio Players & Recorders
