FixYa.com
JVC RX-8020V 5.1 Channels Receiver
All Products > JVC > Receivers
Problems with JVC RX-8020V 5.1 Channels Receiver?
Troubleshooting and Support
Solved Problems for JVC RX-8020V 5.1 Channels Receiver RSS Feed Post a New Problem
Subwoofer-no output
Yes, it is an active subwoofer, & I have tried it with both subs I have to no avail (both subs work with my other...
1 Solution
No subwoofer output-JVC RX-8020V
Yes, I already had the sub activated, & set the level at +6. Any more suggestions? I bought this as an entry level...
1 Solution
No subwoofer output
Just purchased JVC RX-8020V, & have no output from sub. This sub works with my other system, so I know the sub is...
1 Solution
i have a Panasonic SC-PT560EB-K.
i have a Panasonic SC-PT560EB-K. all speakers work on the test tone but the 2 smal "surround" speakers...
1 Solution
what type of amplifier should
what type of amplifier should I use for speakers on Roland vs-1880?
1 Solution
need operating instructions for Technics
need operating instructions for Technics SL 1700
1 Solution
WHEN I ON MY HI
WHEN I ON MY HI FI SYSTEM THERE IS NO SOUND COMING OUT OF THE SPRAKERS, AND WHEN I INCRESE THE THE VOLUME TO 16 OR ABOVE...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for JVC RX-8020V 5.1 Channels Receiver RSS Feed Post a New Problem
Subwoofer-no output
Yes, I already had all of these adjusted as follows: Sub is showing under rt & lf front speakers, volume...
Post a Solution
Suvwoofer- no output
Yes, it is a self powered sub, & I have tried with both subs I have to no avail (both work with my other system). I...
Post a Solution
shuts off
my reciever turns on and the stand by light stays on then turns off about 4 seconds later. i unplugged all the speaker...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeReceiver
Surround SoundDolby Digital® · DTS ES® · Dolby Pro Logic II
Number of Channels5.1 Channels
Stereo Mode Power100 Watt @ 8 ohm, 1 kHz, THD: 0.8%
Surround Mode Power100 Watt @ 8 ohm, 1 kHz, THD: 0.8%
THX CertificationNo
DSP
DSP ModesHall · Theater · Live Club · Pavilion
Inputs / Outputs
Rear Input ConnectorsComponent x 2 · Digital Coaxial x 1 · RCA (2 Audio Channels) x 7 · Composite (Video) x 5 · S-Video x 5 · Digital Optical x 3
Surround Analog Inputs5.1 Channels x 1
Preamp Outputs7.1 Channels
Rear Output ConnectorsComponent x 1 · Digital Optical x 1 · RCA (2 Audio Channels) x 4 · Composite (Video) x 3 · S-Video x 3
Front A/V ConnectionsHeadphones x 1 · Composite x 1 · S-Video x 1 · Couple RCA Jack x 1 · Optical x 1
PC InterfaceUSB
Convenience
Tuner Presets45 Channels
Tone ControlsBass
Remote Control
DesignKeypad with Display
Dimensions
Depth16.75 in.
Height6.19 in.
Width17.19 in.
Weight25.4 lb.
JVC Contact Information
Main support number(800) 252-5722
Email supportproinfo@jvc.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
