20 Most Recent
Jwin JD-VD745 Questions & Answers
JWIN JD-VD745 won't read DVD. It will start but
When the DVD drawer is open you'll see a small plastic lens and a little runner assembly. Clean the lens with a cotton swab dipped in 90% alcohol and swab it dry with the other end. Clean the metal runner with a swab too.
Try a DVD again
DVD WONT PLAY IT SAYING NO DISK OR OPEN.
Try a dvd lens cleaner if the dvd player wont play the dvd. if the dvd drive doesn't work at all you will have to take it to your dealer or Jwin for repairs, how is your warranty?
Tv wont reset
Replace its main system control memory IC, and make an initialize.
If you wish to get more details, surf the
following link. There are over two thousand and four hundred posts. All are
related to television and other domestic electronic equipment service help. You
can get a solution there. Type in the brand name to your device to its search
box, can be located at the top right of the display window. It will make search
easy. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
Supergirl 13 color tv/dvd combo plays CDs but not DVDs...
If cleaning did not fix it the optical pickup for that unit is damaged in some way---if the set has audio/video INPUT jacks on it just buy a DVD player and hook it to the set.If no jacks you are finished--DVD portion of the unit if available costs more than the entire set.
I put in a dvd
You may want to try cleaning the drive using a drive cleaning disc, otherwise it's probably time to get a new one.
-=/ MLFnet /=-
