20 Most Recent Jwin JD-VD130 DVD Player Questions & Answers
re check the connection from audio output jack of the dvd player going to the audio input of the tv replaced the wire if their is a loose connection. if the wires and the connection are good, the problem is with in the dvd player. if your dvd player is brand new and covered with warranty ask for assistance at the supplier.
Jwin JD-VD130... | Answered on Nov 18, 2012
Try these WEB site -
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Jwin JD-VD130... | Answered on Oct 23, 2012
Try these WEB sites to make the player region free.
This WEB site may help -
Check on the remote control if this have this function and disable it
Jwin JD-VD130... | Answered on Aug 26, 2011
I've had this problem once. You should carefully open up the casing and remove the disc manually. Close the cabinet and you're back in business.
Jwin JD-VD130... | Answered on Feb 06, 2011
chak ur video op cable u plug it on worng socet
try onther socet to plugin
Jwin JD-VD130... | Answered on Oct 15, 2008
I just kept pressing all the buttons on the remote , one at a time until the picture came back on. I am not sure which button resovled it -- I think it was the osd button or the ps/is button  . Thank you
Jwin JD-VD130... | Answered on Jun 10, 2008
Are you referring to a prerecorded commercially produced DVD?
Discs are Region Coded This means that you will not be able to watch DVDs intended for use in a different country, unless you have a multi region player. .
There are two video standard formats, NTSC which is mostly North America, and PAL which is the rest of the world. Some players will play both, others won't. Some DVD players allow you to select the format.
Jwin JD-VD130... | Answered on Feb 23, 2008
Uhm..
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Jwin JD-VD130... | Answered on Jan 23, 2008
Jwin JD-VD130 DVD Player Logo
16 questions posted
Top Jwin Televison & Video Experts
Jaime Hernandez
Sheldon Dedek
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jwin Televison & Video
Most Popular Question
got audio no video
  • Televison & Video
