20 Most Recent Sony PlayStation 4 Questions & Answers
connection error 3316 u have to reset your ps4 controller . on the back there should be a small hole that u can insert a needle through then reset it then connect it through wire and it should work fine.
Sony PlayStation... | Answered on Jan 18, 2018
If you want to know about the whole process of upgrading a PS4 HDD (hard drive) on your system, you can go through the PS4 External Hard Drive, as they would provide you the easiest guidelines to upgrade your HDD very easily.
You can also get here expert IT professionals guidelines for various devices of your PS4.
Sony PlayStation... | Answered on Jun 06, 2017
  1. There are some of the specifications that you can look for to get a Hard Disk Drive is as follows -
  • 2.5-inch form factor.
  • 9.5mm thick or less.
  • Interfaced with Serial ATA (SATA) only.
  • Hard drive's type doesn't matter.
  • Speed also doesn't matter.
You can also get the detailed knowledge on the specifications that you must follow and other details through one of the best site that I've been using since last year to get all the details on latest updates, and many more from PS4 hard drive.
maybe its not available in ur place
Sony PlayStation... | Answered on Apr 17, 2017
Could be a network issue with your router or your PS4 settings I would try and do a hard reset on your router which is remove the battery back up if you have one and unplug your modem and router for 60 seconds then plug in modem first let it come all the way up then plug in your router and let it boot all the way thru then retry connecting. If this don't work reset network settings on your PS4 to factory defaults. Hope this helps
Sony PlayStation... | Answered on Mar 15, 2017
did you put the code into the "redeem code" section?
Sony PlayStation... | Answered on Feb 02, 2017
network is up and running. could be your wifi or network connection
ask your newtwork provider
Sony PlayStation... | Answered on Jan 04, 2017
If its not available in the playstation store its not available. (Yet)
Sony PlayStation... | Answered on Dec 02, 2016
It is possible you have forgotten your password so I recommend picking that option and going through the steps on resetting your password. If this doesn't work then I would recommend contacting Sony support and they can tell you what the email for a specific username is.
Sony PlayStation... | Answered on Oct 16, 2016
If your term of "easy" means exploits or something similar, then no. All the exploits as far as I am aware have been patched. If you're looking for methods the best thing I can recommend is completing the criminal master mind challenge as it pays out 10 million per person and is much easier than you may think with a well-coordinated team. There is also the fact that once a person dies you can simply close the application and it will not reset the challenge. Other than that just grinding missions and keeping an eye out for events is the only way.
not enough ram memory
chip not fast enough
os system too old
discuss possible slow operations with a computer repair shop
Sony PlayStation... | Answered on Oct 14, 2016
is it sata enabled
is it big enough for the application ( GBs)
is it of quality manufacture
Kingston is a good brand , economical to buy , it is Sata rated and a 125 gb will replace a 250gb disc hard drive
Like all things , talk with a computer repair shop
Sign into your YouTube account. There should be an activation code if you haven't linked it to your ps4. Go to YouTube on your computer and BAM input that sucker in there and you should be good to go!
Sony PlayStation... | Answered on May 14, 2016
Depending on which account you have an email with (gmail,yahoo,hotmail etc...) there should be a place where you log in that says something along the lines of "forgot password" and they should send either a text or email to a back up email with a reset password and it will walk you through the new set up.
Sony PlayStation 4 Logo
89 questions posted
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
PlayStation Sony
  • PlayStation Sony
Most Popular Question
get ps4 play via nec np310 projector no
  • Video Game Consoles & Games
