My 42'' LG Plasma TV (RU-42PZ71) recently started to malfunction. After a 3 second turn on time, the...
(More)
My 42'' LG Plasma TV (RU-42PZ71) recently started to malfunction. After a 3 second turn on time, the screen displays a vertical bar of multiple colored noise on the far right of the screen for 4 seconds, then the bar begins to move to various locations on the screen. This is repeatable as I change the video input. The TV tuner input behaves differently, the entire screen shows the multiple noise color. I can not display the menu or any other information on the screen.
I was told a ''power supply'' was the issue, not sure what board? Any help would be appreciated. Here is a list of boards in the TV:
Main PS: 3501V00182A
YSUS: 6871QYH029A
ZSUS: 6871QZH033A
All fuses checked out ok.
Thanks,
Alex
have a lg ru 42pz71 tv power light on but tv is blank can here it click on but nothing on screen no...
(More)
have a lg ru 42pz71 tv power light on but tv is blank can here it click on but nothing on screen no sound just acts dead
my lg 42in plasma has dark screen with what looks like large ink spots on the screen. the sound...
(More)
my lg 42in plasma has dark screen with what looks like large ink spots on the screen. the sound works fine. i have replaced all fuses. i also cannot view the user menu. it is blacked out also. Its an LG RU-42PZ71
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
Michael from Queens, New York Purchase a LG 42" HDTV connected it to Direct TV service, while on the regular service no problem, but went to...
written by mwv2001
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
