how much is a new picture tube for this model? a tv repair guy said thats what it needs. price/where...
(More)
how much is a new picture tube for this model? a tv repair guy said thats what it needs. price/where can i get it
Can't change input source for "auto on" function. Need to get "HDMI 1" to be...
(More)
Can't change input source for "auto on" function. Need to get "HDMI 1" to be input source when unit turns on, not "TV 3 - 0". When I go to menu and try to switch inputs for auto on, I get no other selection options.
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
Michael from Queens, New York Purchase a LG 42" HDTV connected it to Direct TV service, while on the regular service no problem, but went to...
written by mwv2001
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
Composite x 1 · Audio (Mini Jack) x 1 · S-Video x 1 · Component x 1 · Audio (RCA) x 2 · 1 x D-Sub (RGB PC) · RF x 2 · 1 x RS-232C · HDMI x 1 · FireWire x 2
Memory Card Slot
CompactFlash Card · SD Card · SmartMedia Card · MMC Card · IBM Microdrive · CompactFlash Card Type I · CompactFlash Card Type II · Memory Stick · xD Picture Card · Memory Stick Pro
