20 Most Recent
LG 60PY2DR Television Questions & Answers
My lg 60py2dr has 2 problems, 1st every once in
For $4000.00 you probably mean the panel or screen. I would say probably th plasma panel. They are very expensive. I would never buy one of these tvs without buying the extended warranty offer by the retailer. Sad to say though the price of these sets has come down considerable and the picture quality has improved significantly. for close to the price to repair this set you could buy a new set and definitly buy the extended warranty.
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
How do I find for DVD BD370 the Multiregion code
Please follow the steps
1.Download http://www.multi-region.net/_media/6000.zip
2.Extract the files
3.Burn the directory RMTM0000 to a CD-R
4.Write mode: ISO format, Mode 1, ISO 9660.
5.Put the CD-R into the player
6.When the Region Management System screen is displayed, set the Region Code to “0” using your remote.
7.Press PAUSE
8.Your are done
Thanx
