Can I record one Freeview programme and watch another with this machine. My tv does not have a...
(More)
Can I record one Freeview programme and watch another with this machine. My tv does not have a digital tuner. LG DVD recorder DR 4810. I am in Cornwall so we are completely digital.
Hi iam balram yadav, i have lg Dr 165, when ever i record it displayed msg "Unkown disc format...
(More)
Hi iam balram yadav, i have lg Dr 165, when ever i record it displayed msg "Unkown disc format want to initialize the disc ?". I found this type of messages randomly on it. and disc is not finalized, ido know in which format it records, without finlaizing any computer will not read. please tell me those dvd is how to recover it, which software able to read (not finalized dvds) & recover it thanking you please solve my problem
Display shows PLEASE WAIT over and over again. Will not eject discs. The unit is about 5 years old,...
(More)
Display shows PLEASE WAIT over and over again. Will not eject discs. The unit is about 5 years old, I replaced the drive but no change. I have heard it is likely to be the power supply is there anything I can do or should just recycle the whole thing minus the drive which is ok.
is there a converter to run my LG dvd player that was sold in France & has a European plug...
(More)
is there a converter to run my LG dvd player that was sold in France & has a European plug that indicates 250 volts.
The play,record,home, return functions will not work from remote, although will work if pressed on...
(More)
The play,record,home, return functions will not work from remote, although will work if pressed on machine itself. The on/off, eject/close and program(channel)change work on remote but that is it. This happened overnight
i have this dvd lg dr165. after one year of using suddenly it's started to change channels by...
(More)
i have this dvd lg dr165. after one year of using suddenly it's started to change channels by himself. i didn't successed to stop this strange thing. please help !!!
Habe eine grosse Menge DVD -RW von Sony aufgenommen, konnte die Spielfilme aber weder Im Ausland...
(More)
Habe eine grosse Menge DVD -RW von Sony aufgenommen, konnte die Spielfilme aber weder Im Ausland noch sp??ter auf fremden Ger??ten sehen.
Die Firma Fust steht auch vor einem R??tsel.
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
