LG DU-62SY20D 62 in. Rear Projection HDTV Television
Problems with LG DU-62SY20D 62 in. Rear Projection HDTV...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
LG DU-62SY20D 62 in. Rear Projection...
Troubleshooting and Support
Solved Problems for LG DU-62SY20D 62 in. Rear Projection HDTV Television RSS Feed
View More Results for LG DU-62SY20D 62 in. Rear Projection HDTV Television
Questions and Unsolved Support Problems
Unsolved Problems for LG DU-62SY20D 62 in. Rear Projection HDTV Television RSS Feed
Answer
My sister just bought a Samsung DynaFlat HD TV and there's color in the menu, but not in any other... (More)
Answer
I have a display video 6 in the upper left hand of the screen, it stays on continuously. I know it... (More)
Answer
New 65 " HD Projection Mitsubishi is turning all picture flourescent colors, why?
Answer
my lg 62 inch tv seems to be working fine however on the front of the tv is just below the power on... (More)
Answer
I have Mitsubishi 65869 HD rear projection TV. Recently, every now and then it turns off by itself... (More)
Answer
black and white picture in tv when hooked up to pc with rca plugs.
Answer
Mitsubishi 65869 with convergence problem - Won't respond to manual adjustment and won't reset. Is... (More)
Find a Manual
LG DU-62SY20D 62 in. Rear Projection HDTV Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the LG DU-62SY20D 62 in. Rear Projection HDTV...
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for LG DU-62SY20D 62 in. Rear Projection HDTV Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for LG DU-62SY20D 62 in. Rear Projection HDTV Television
Key Features
Screen Size
62 inch
Display Format
1080p (HDTV)
Digital TV Standard
HDTV
Projector Technology
DLP
Display Capabilities
Aspect Ratio
16:9
Built-in Tuner
ATSC
Warranty
Overall Warranty
1 Year
LG Contact Information
Main support number1-800-243-0000
Email supportcustomerservice@lge.com
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
