20 Most Recent
iRiver E200 (8 GB) Digital Media Player Questions & Answers
Does the iriver e200 need a battery change
All MP3 players need their battery charged before you cam play music.You charge the player with the supplied USB cable when it is connected to the USB port on a computer.
How to put a movie in my ipod?
Check the specification of your MP3 player to determine thetype of video file format it uses.
Most common video files that MP3 players use are, AVI andWMV, there may be others such as FLV, MOV and DivX.
If your player cannot play a video then it is anincompatible video file format, then you need to convert that video file to aformat that your MP3 player uses.
Click on this link for instructions on converting videofiles for MP3 players :-
http://www.fixya.com/support/r5874192-play_videos_mp3_player
My iRiver e200 does hang...and it displays "USB busy.. Do not Disconnect if I connect it to PC. And I cannot play my MP3s
Hi there! Well it sounds like the flash memory in your device has failed. This may not be the case. There is no way to say without testing and diagnostics, however if you can not access the files saved to the memory via the device(Playing the files) and the computer can not access that memory when connected, there is a strong possibility that your memory has failed. I am not sure the age of the device but it is well documented that all flash memory will at some point fail because it can only be read and re/written X amount of times(this is normal). Typically most devices will reach "EOL"(End Of Life), or end of use before the memory fails. The likely hood of recovering the files located within the inaccessible memory is very unlikely but may be possible. Replacing the memory chip in the device is possible but not feasible. I hope I have been able to help you today. Please if I misunderstood your question let me know so I can get you the appropriate help. Thank's Mr.Mike
