20 Most Recent Roland Boss Gt-10 Guitar Effects Processor Gt10 Open Questions & Answers
Request the schematic diagram directly from Roland.
Roland Boss... | Answered on Dec 08, 2017
If you buy a second hand, it may have been damaged in mini switch (tact switch) under the WRITE button. You need to replace the tact switch. Easy and inexpensive, you can do yourself, only with a little knowledge of soldering
Tact Switch:patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-1.jpeg
You may also try the FACTORY RESET.
Restoring the GT-10 to the settings made at the factory is referred to as a "Factory Reset."
Not only can you return all of the settings to the values in effect when the GT-10 was shipped from the factory, you can also specify the range of settings to be reset.
If you do this"Factory Reset", all the setting on user memory (that you create) will be erased, so backup your setting before doing this steps.
patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-3.jpgpatch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-6.jpg
For more detail on "Factory Reset", read the GT10 user manual:
roland.com/support/article/?q=manuals&p=GT-10&id=1810803
Roland Boss... | Answered on Dec 06, 2017
what is your question?
if not working, you have to open the device and find out where it is not connecting (broken solder joint? bent or worn out contacts? wire off?) and repair. or if beyond repair, order a new part.
Roland Boss... | Answered on Apr 13, 2017
The first step would be to re-initialize the unit. Here's a link to the process-
BOSS Support Knowledge Base GT 10 Factory Reset Initialization
Roland Boss... | Answered on Jan 25, 2017
Julio, If you already changed power supply and no success, it is probably a bad solder joint on board. I will post a link below that may help or you can try a forum.
http://roland.com/support/article/?q=manuals&p=GT-10
Roland Boss... | Answered on Feb 20, 2016
There is a small chance it "could" but more likely you would just overdrive the input stage to clipping.
You can try it- you need to keep the viltage input to the amp at 1 volt peak to peak or less, or you run the risk of clipping. You should use shielded cable, as you may also pick up other noise along that cable.
Roland Boss... | Answered on Mar 29, 2012
Check for intermittent connections of cables. The vibration of turning it off and on MAY be fixing a poor connection. Verify the problem exists using new cables. Intermittent problems are tricky to find so we have to do tests to narrow the possibilities.
Roland Boss... | Answered on Apr 25, 2011
The half-way cord is the clue. Read up on unbalanced and balanced lines and TRS connectors.
One of these requires TRS connections and the signal is being carried on the RING of the TIP-RING-SLEEVE connector. Plugging in half-way the TIP touches the ring pickup contact. The emgs one MAY use TRS type cables and there may be a reason the signal and hot of these are reversed. If I could find schematics on all this equipment I could unravel the exact cause. You could make an adapter with a Stereo 1/4 inch plug and a 1/4 inch jack by wiring it to swap the tip and ring between them to use for connecting to the emgs guitar. ALSO verify you are using the SAME type guitar cable for both.OFTEN a TRS cable will NOT turn on the electronics when plugged into a guitar. Use an unbalanced instrument cable unless you have the XLR type output. Use of an adapter from the XLR type cable into the Boss will usually not work.
This is far from normal. What may be the problem is a component on the circuit board itself. You may have to take this to someone who has a multimeter to test and see which one it is (this may take a while, since there are a LOT of small components). If you don't want to (or have the money to) do that, you can just set the balance to the opposite side of the louder speaker until it sounds even out of both channels. Eventually, though, something will have to be fixed.
Hope that helped!
Roland Boss... | Answered on Feb 11, 2011
Well first off put it back where it was originally. if that doesn't fix it you've probabple blown the transformer in the power supply and it will needt o be replaced.
Roland Music | Answered on May 28, 2018
Roland Boss Gt-10 Guitar Effects Processor Gt10 Open Logo
Popular Tags
18 questions posted
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
View Most Popular
Roland Music
  • Roland Music
Most Popular Question
suddenly stoped working doesnt turn
  • Music
