20 Most Recent
PANDIGITAL 5.6 DPF56-2 64MB 320x234 Digital Photo Frame - Plays Questions & Answers
How can I get a copy of the manuel for my pandigital 5.6 inch digital photo
Three queries with a common theme - methinks you may be obsessing somewhat.
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual note spelling, then follow the appropriate link(s). Or, you could look at the responses to other, similar, queries.
Why My trittOn warhead 7.1 headset port keeps blinking
There are a couple things that could blink on a Tritton Warhead 7.1 headset:
1. The round quadrant on the base station
2. The sync button on the headset piece itself
On 1. That means you have to sync it with your Xbox. Press the button on the Xbox that you would usually pres to sync a controller (it kind of has 3))) on it) and then press the sync button on the base station. they should sync up, then you have to press the ( 3 ))) ) ones on the inside of the headset until the quadrant on the Base Station is the same as on your controller.
2. that means that the headset is not connected to the base station. Try to unplug it form the power socket but if you get no lights on the base station at all it might be faulty or the power adapter might be faulty
You get 2 yars of warranty from the purchase date so submit a ticket on support.madcatz.com
Film won't load on Vectis 300 MinoIta
The clue is in your descrition; Old.
If the mechanism has jammed, due to age or lack of use that causes tarnisg=hing on the contacts, the motor/mechanism will not load.
I would get it serviced at an aurgorised Minolta repair shop.
Contact Minolta for a list of authorised repairers.
3/22/2024 7:04:40 AM •
Photography
Answered
on Mar 22, 2024
I tried to use a 16GB PNYcard in my picture fram and it would not work. It said "No Card" on the screen. What's the answer?
If your picture frame is not recognizing the 16GB PNY card and displaying a "No Card" message, there could be several reasons for this issue:
- Compatibility: Some picture frames may have limitations on the size or type of memory card they can accept. Ensure that the picture frame is compatible with SDHC or SDXC cards, as these are the types commonly used for higher-capacity cards like 16GB.
- File System: Check if the memory card is formatted in a compatible file system such as FAT32 or exFAT. Some picture frames may not recognize cards formatted in other file systems. You may need to format the card using a compatible file system on your computer before using it in the picture frame.
- Card Reader Slot: Ensure that the memory card is inserted correctly into the card reader slot of the picture frame. Sometimes, improper insertion can prevent the device from detecting the card.
- Card Compatibility: While SDHC and SDXC cards are generally backward-compatible with devices that support SD cards, some older picture frames may have limited compatibility with higher-capacity SD cards. Try using a lower-capacity SD card (e.g., 2GB or 4GB) to see if the picture frame recognizes it.
- Faulty Card or Picture Frame: If none of the above solutions work, there may be an issue with either the memory card or the picture frame itself. Try using the memory card in a different device to check if it's functioning correctly. Similarly, try using a different memory card in the picture frame to see if it's able to recognize it. If the problem persists, there may be a hardware issue with either the card or the picture frame, and you may need to contact the manufacturer for assistance or consider replacing the faulty component.
By following these troubleshooting steps, you should be able to determine the cause of the issue and resolve it accordingly.
3/16/2024 9:30:07 AM •
Photography
Answered
on Mar 16, 2024
