20 Most Recent Williams Allegro 88-Key Digital Piano Questions & Answers
Assuming this has worked in the past (otherwise if you have changed to different pedal that is the problem) the usual thing is the machine samples the state of the pedal at power up and assumes the polarity of the pedal is at rest. Make sure you are not pressing it as you power up. Also verify the pedal is COMPLETELY plugged in... sometimes they are not quite fully in and that causes a problem, especially with the two stage versions that are sometimes used.
Williams Allegro... | Answered on Dec 05, 2017
As you didn't tell us the make and model, we can't be much help. You should conytact the Customer Service Department of whoever manufactured the instrument.
Williams Allegro... | Answered on Mar 20, 2017
Hi Kyle:
Have a look at your manual.
Sometimes you'll find that there will be an "input" setting required.
You might also try google with his link.
https://www.google.ca/#q=Williams+Allegro+88-Key+Digital+Piano
Hope this helps.
Cheers.
Williams Allegro... | Answered on Oct 13, 2015
You probably want to connect to an audio input.
Williams Allegro... | Answered on Oct 08, 2014
Check if front of key is hitting the case. If it is, analyze why it is happening. If unit has been dropped this can happen. One can sometimes move the whole key assembly back slightly if this is the problem.
Williams Allegro... | Answered on Jan 26, 2014
You have to plug in the laptop sorry to say. Think of it as a piano that can be used as a midi controller.
Williams Allegro... | Answered on Jan 30, 2012
http://www.williamspianos.com/products/Williams%20Allegro%20manual_LR.pdf
Williams Allegro... | Answered on Oct 25, 2011
Take it back to the store (send it back to the store but call first to get a return authorization if you got it online). This sounds like a manufactures defect. It shouldn't work that way.
You can also try calling Yamaha (good customer service historically). Check your packaging for their number. They usually prefer that you call them to get things fixed instead of returning it.
I would not recommend trying any quick fixes anyone else recommends because they can invalidate your warranty from Yamaha
Good luck.
Williams Allegro... | Answered on Sep 15, 2011
If this is a brand new unit, exercise your warranty!
BUT FIRST see if packing material worked through the speaker grill... you know littel pieces of the packing peanuts or otherr contamination that sits in the speaker cone and rattles.
Williams Allegro... | Answered on Feb 12, 2011
Williams Allegro 88-Key Digital Piano Logo
26 questions posted
Top Williams Music Experts
Michial Gueffroy
Are you a Williams Music Expert? Answer questions, earn points and help others
View Most Popular
Williams Music
  • Williams Music
Most Popular Question
midi settings
  • Music
