20 Most Recent Honeywell 5816WMWH, Wireless Door/Window Transmitter w/Magnet, White Questions & Answers
Why does a 5816 door sensor in my Lynx 5200 system send a fault message even when system is disarmed?
Jon, I am not 100% sure what you are asking about. However, is the keypad shows 'Ready to Arm' when the door is closed and then shows the front door in fault when you open it, then that is how it is supposed to work. When the system sees a door open or movement, then it shows on the zone in fault on the leypad. If you were to try and set the alarm with the door open, the system can tell you which zone needs to be corrected before you can set it. Usually it is as simple as closing a door or window. When the door is closed and it says that it is ready to arm, you are good to set and leave. Opening the door with the alarm off or on will report on the keypad.
1/2/2015 8:16:37 PM • Honeywell... • Answered on Jan 02, 2015
DOOR/WINDOW SENSOR NOT WORKING
There should be two parts to the sensor. Make sure both are paired up evenly within a inch of distance. A system or panel reset might be necessary.
4/20/2014 5:37:18 AM • Honeywell... • Answered on Apr 20, 2014
2answers
My Honeywell Safe model 5005W keeps beeping, even though I put new batteries in it. What do I need to do, to shut it up?
The batteries must be installed before using your safe. The battery compartment is located inside the safe on the lock cover panel. Note: If both green and red LED's are on, it is an indicator that the batteries are weak and must be changed immediately. The User Code will not be erased if power is restored by replacing the batteries within 30 minutes. After 30 minutes, the User Code will be erased and will need to be reprogrammed. Weak or dead batteries should be replaced immediately and all 4 batteries should be changed. To replace the batteries please follow STEPS 1 - 3. Remember to always remove batteries from safe if not using for an extended period of time. If your batteries are completely dead and you cannot o pen the safe by using the digital keypad, use the override access key to open safe and access the battery compartment. The use of Non-alkaline or rechargeable batteries is NOT RECOMMENDED.
9/3/2023 11:15:05 PM • Honeywell Home... • Answered on Sep 03, 2023
Weather security camera my asking wires
" Weather security camera my asking wires ". Well I read it 8 times and still no clue. Why do you have a security camera for looking at the weather? Why is the camera asking you for wires? Green is normally Ground, but may depend on the make and model. https://www.google.com/search?q=security+camera+wiring+colors ..
12/23/2022 11:18:18 PM • Honeywell Home... • Answered on Dec 23, 2022
2answers
How to get my Honeywell home security system to recognize my motion sensor after I changed it's battery
Make sure the cover is properly seated. Enter your code and off twice. Enter programming mode with your installer code and 800, then exit programming mode with *99. Let me know what the keypad displays after completing these steps.
6/21/2022 9:19:08 AM • Honeywell Home... • Answered on Jun 21, 2022
Tamper fault on accenta g4
Hi there, where do I get those 2 screws from? I also have G4 accenta, but I lost both screws and it keeps saying tamper release or something because the spring is not in place due to the wrong screws.
4/9/2022 11:58:45 AM • Honeywell Home... • Answered on Apr 09, 2022
I have a Honeywell Ademco 6160 Alpha Keypad Vista . I can't hear the beeps. Is there anything I can do to change the beeper frequency?
In a word no. It uses a piezo electric transducer that works on a fixed frequency.
4/5/2022 6:44:14 AM • Honeywell Home... • Answered on Apr 05, 2022
2answers
Manual for Honeywell vista 20P
Contact Honeywell directly to request the manual.
10/30/2020 10:55:50 AM • Honeywell Home... • Answered on Oct 30, 2020
Password reset for honeywell dvr
first ensure the DVR is attached to your router, then you will need to contact Honeywell tech support. They will ask for the MAC and serial number. They will give a temporary password. It is important to change the password once unlocked, because the temporary password will not continue to work.
9/12/2019 5:15:12 AM • Honeywell Home... • Answered on Sep 12, 2019
Keypad restarting at random
Sounds like you have a power issue. Check the current output of the positive terminal. You need to do this by connecting an ammeter in series with all wires that are currently connected to the positive terminal of the control panel.
6/5/2019 7:44:34 PM • Honeywell Home... • Answered on Jun 05, 2019
6160 honeywell key pad is counting up with the word fault in front. Whats causing it and how can i fix it
hit your code and off twice, then hit the * key. Let me know what is displayed.
6/5/2019 7:36:43 PM • Honeywell Home... • Answered on Jun 05, 2019
Honeywell alarm sytem 94 on the screen ??
It means that there is something wrong with the phone line. Check for dial tone on the red and green terminals. If you don't have a test set, then check for DC voltage. It should be about 48 volts with all phones on hook. The voltage will drop when someone picks up a phone.
6/5/2019 7:34:48 PM • Honeywell Home... • Answered on Jun 05, 2019
What is the dafault password of honeywell dvr
Should be admin. If you have changed the password to something else, then the default password no longer exists.
3/2/2019 2:20:40 AM • Honeywell Home... • Answered on Mar 02, 2019
I am getting an Communication error 103 on my Honeywell alarm system. Cannot get it to go away. Suggestions?
This could be a lot of things and it is dependant on what keypad you have. It could be a cell tower signal loss or interference, it could be a router or modem issue on you devices, it could be one of 11 other things. IF you have the vista keypad, look for a four digit error code extension.
2/16/2019 3:16:02 AM • Honeywell Home... • Answered on Feb 16, 2019
Honeywell vista 20 wire 107 109 trouble message error on key pad what does this mean? also found 1 expander led light off and those zones are open, i attempt bypass now all are in trouble?
Let's start with the 107 wire expansion fault your getting. Yes that is the wired expansion/zone expander wired to the data bus which is the same four wires that the keypads use. Their should be a schematic on the door of your panel but they should be on terminals 4,5,6,7 on your main alarm panel. Aux power positive, Aux power negative, Data A/IN, Data B/OUT. That message on the keypad is telling you that that expander is not communicating. Take a multimeter and check for 12 volts DC on the bus connections at the expander. They should be the red and black wires. Be sure to check the labeling on the circuit board though. Start there and let me know. I'm available for direct call/video chat at the link below.https://www.6ya.com/steven_ce753208b7672ed6
2/6/2019 5:24:53 PM • Honeywell Home... • Answered on Feb 06, 2019
2answers
How do I factory reset a Honeywell HRGX45 DVR
How to reset admin password Honeywell Black dvr
1/8/2019 12:18:20 PM • Honeywell Home... • Answered on Jan 08, 2019
How to remove the FC code off Honeywell system what keys to press do not have a plus sign on keypad.
you need the installer code to enter programming, then exit programming. that will clear the FC (failure to communicate)
10/24/2018 6:58:10 PM • Honeywell Home... • Answered on Oct 24, 2018
How can I add security cameras to my lynx alarm system
You cant. Upgrade you system to Ademco quick connect and if you have ADT add "Pulse". 0ed4b61b-897e-406a-8611-aad951c95dd8.jpg
9/3/2018 7:53:41 AM • Honeywell Home... • Answered on Sep 03, 2018
Honeywell 5816WMWH, Wireless Door/Window Transmitter w/Magnet, White Logo
Popular Tags
3 questions posted
Top Honeywell Home Security Experts
Jay Finke
Jay Finke
deton8 von Splosion
ADMIN Andrew
ADMIN Andrew
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
View Most Popular
  • Honeywell Home Security
Most Popular Question
5816 door sensor in lynx 5200 system
  • Home Security
