20 Most Recent Seagate USB 2.0 External Enclosure + 300GB BARRACUDA 7200-ULTRA ATA/100 8MB-ST3300831A (NEWITEM31866554) Drive Case Questions & Answers
I recently received a Seagate 500GB external
Go to seagate web site and get software to reformat the drive.
7/12/2017 8:50:25 PM • Seagate USB 2.0... • Answered on Jul 12, 2017
Seagate barracuda + usb harddrive enclosure cant access hard dive
First, neither of the links work. The amazon shows a power adapter and the Seagate defaults to their home page. But I think I get the idea. You purchased a usb drive enclosure and a new hard drive and now it doesn't work. The problem is that the hard drive has not been initiated, formatted or assigned a drive letter. Plug in the drive Click on the Start button Right click on Computer Select Manage A screen opens, click on Disk Management All the drives known and unknown will appear on the right. Find the drive that says unknown, right click over the text and select Initialize Disk. When done, right click the blank space to the right labelled Unallocated and select new simple volume then follow the steps to format and assign a drive letter. If you are only going to be using this drive on this computer then format ntfs, if it maybe be connected to other devices including Mac, you may want to use fat32 or exfat. Whats the Difference Between FAT32 exFAT and NTFS
3/1/2017 7:27:52 PM • Seagate USB 2.0... • Answered on Mar 01, 2017
I have a seagate ultra model 300 gig external hard
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
If nothing works , it would be best to take the drive to data recovery experts.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
9/29/2010 8:53:46 AM • Seagate USB 2.0... • Answered on Sep 29, 2010
I have a seagate external hard drive that I
Are you using XP?
It should show up. Are yo sure you are plugged in correctly everywhere?
Check your device manager ...
Let me know if this works for you.
a
9/26/2009 2:01:13 AM • Seagate USB 2.0... • Answered on Sep 26, 2009
2answers
I recently added a Seagate
Hi!
I think I would run the setup application and see if it helps. You're relying on the Windows drivers for the drive and who knows how well they work.
1. Turn the computer off completely.
2. Disconnect the USB drive and any other USB devices (for the time being).
3. Turn the computer back on, put the installation disk in and follow the instructions. Don't connect the USB drive until you are asked! Having it connected before asked may not allow the installation process to work as it should.
4. When everything is installed, hook your other USB devices back up and see what happens.
If this doesn't work, go to the Seagate site and try out their external HD troubleshooter.
Hope that helps! Remember to rate the solutions!
8/10/2009 6:53:38 PM • Seagate USB 2.0... • Answered on Aug 10, 2009
How to delete backup on my seagate backup plus slim
Detailed steps to manage backup disk space
To delete old backups on Windows 7/8/10 using AOMEI Backupper, you need to set up Backup Scheme during the process of creating a backup. When your backup versions exceed the number of backup images files, AOMEI Backupper will delete older backup automatically. Step 1: Connect your Seagate Backup Plus drive or Central hard drive to the computer and make sure it can be detected by your computer. Step 2: Download AOMEI Backupper Professional, install and launch it. Step 3: Click Backup and File Backup subsequently Step 4: Choose the files and folders you want to backup and pitch on a path for it. Then, Click Schedule option and select Schedule Settingsfrom the following window. Step 5: Click Scheme option, tick Enable Disk Space Management and select whatever Scheme you need from the drop-down menu. Then, back to the main page of File Backup and click Start Backup. After that, your older backup will be deleted automatically when your file backups exceed the versions of backup image files.
2/26/2024 7:21:41 AM • Seagate... • Answered on Feb 26, 2024
Ive got a 8tb seagate its got a blinking blue light and wont connect to my Pc? Any help?
Did you initialize it?
7/3/2023 8:38:03 AM • Seagate... • Answered on Jul 03, 2023
Seagate Portable Hard drive 4TB, part number 2N1AP6-500
Hi, Please put your computer into safe mode before attempting to connect to the hard drive again. Safe mode turns some feature off when activated so whatever program is forcing the shutdown might have be paused when connecting to the external hard drive. Also, try connecting the hard drive to a non-laptop intermediary device and then connecting that device to your computer and attempting to access the hard drive folder within the intermediary drive. Thank you.
11/11/2022 2:11:28 AM • Seagate... • Answered on Nov 11, 2022
2answers
How to recover data from a dead Seagate external hard drive on my Computer?
Should be careful with the data file deposited on the Seagate external hard drive. your Seagate external hard drive might be dead or corrupted. In this situation, you might need to rely on data recovery software to get back data and files on the dead Seagate external hard drive. So you can rely on data recovery software to get back lost data and files when the Seagate external hard drive is dead and inaccessible. Data recovery hong kong technician provide the Ontrack EasyRecovery data recovery services are able to recover data and files from accidentally formatting, corruption, virus attack, dead, system crash under different situations Seagate external hard drive on Windows Computer. This data recovery software allows you to deep scan the dead Seagate external hard drive so as to find out almost all lost files with original quality in a short time. You can also rely on this software to recover files from dead/damaged Seagate external hard drive. The software supports to get more recover: Seagate External hard drive, data file, documents, PDF, Excel, photos, music, and videos any HFS, HFS, FAT, ExFAT, and NTFS format based data and file and more. It will recover data and file from all external storage devices that can be recognized by your Windows PC Computer/Laptop. Hope this helps you get to recover all your lost data and files from your dead Seagate External hard drive.
10/8/2021 1:02:33 PM • Seagate... • Answered on Oct 08, 2021
What enclosure is compatible with a Seagate Barracuda 7200.7 SATA Drive?
TRY LOOKING FOR TIGERDIRECT .COM THEY SELL STUFF FOR COMPUTERS
10/3/2021 8:21:41 PM • Seagate... • Answered on Oct 03, 2021
5answers
Need restore my RAW file system back to NTFS without losing any hard drive files?
There are two options for you to get your drive stuffs back right now: 1). Do not format this RAW file system external hard drive temporarily and plunge it to your PC. And then, choose and apply RAW external hard drive data recovery software to scan this drive and find your preferred drive files back as many as possible. 2). Directly consult some professional data recovery services from some data recovery companies or agencies. In the future, remember to save copies of everything important on at least two devices in case of any similar data loss issues.
1/5/2021 2:43:04 PM • Seagate... • Answered on Jan 05, 2021
I have seagate plugged in and attached to my computer. I downloaded the program but I get the message connect a dashboard enhanced drive to activate features ??
Can you please provide more detail on the program you are downloading, the model of drive, and model of computer?On the face of it, the program seems to be saying it is not compatible with the model of drive you have plugged in, or that the drive has been reformatted in a way that is not compatible. Does the drive show up in the File Explorer / Finder of the machine?after comment : ok, if you can drag and drop files onto it, then That means it is operational, and recognized by the system. The next question is why you can’t install the Seagate Desktop software. Where did you get the software from? Try going to Seagate Support and looking up your drive model, and doing a fresh download of the software they have for that model. Alternatively, there are other backup software packages available, Acronis, Aoemi, EaseUS, and others. You can find reliable downloads of utility software at downloads.com (CNET) or look for reviews from PcWorld or PCMagazine for their recommendations of the best paid and free backup software
10/20/2019 9:49:12 PM • Seagate... • Answered on Oct 20, 2019
Necesito controlador para Seagate medalist 4310
I need controller for (English please) in a computer,. or DVR or what, where does this HDD go? Medalist 4310 (ST34310A) built in 1999 (20 years old ) why use any drive this old. why? it's useless. my wild guess, is this you have a PC and ustated PC has SATA only ports (modern) and this old old HDD is PATA drive, with ribbon cable wide. and you think it can run on modern PC. well they do sell cards (PCI-e) that fit and work. 4.31GB is the size , holds about 1 top movie . are you going to boot from this drive, if yes, very complex answer I will skip here. (ask maker of card , if it can) newegg.com has them all, any thing you can dream of , is there. if you look. https://www.newegg.com/Product/Product.aspx?Item=9SIA4UB8ZU9127&Description=pci-e%2c%20pata%20IDE%20card&cm_re=pci-e%2c_pata_IDE_card-_-17Z-0007-00AF2-_-Product again, no PC stated, no OS stated. nor of booting is needed to the PATA relic drive. from 1999.
4/8/2019 1:42:01 PM • Seagate... • Answered on Apr 08, 2019
4answers
Hi, I accidentally dropped my 2 tb Seagate expansion disc and now its making funny noises andm it wont even read on my windows 8 computer. Can some 1 help me please?
unfortunately it appears that the internals are shot if the funny noise is a clicking sound or squeal then the repair is a new hd unit as they are generally not repairable.
3/27/2019 9:36:59 AM • Seagate... • Answered on Mar 27, 2019
3answers
How to recover data from a dead Seagate external hard drive for beginners
Tutorial to recover data from dead Seagate external hard drive
Step 1: Download & install iBoysoft Data Recovery on your computer. Step 2: Connect the dead Seagate external hard drive to your computer. Step 3: Launch iBoysoft Data Recovery and choose the dead Seagate external hard drive. Step 4: Click "Next" to search for lost files on the dead Seagate external hard drive. Step 5: Preview the searching results. After that, select the lost data and click the "Recover" button to get them back. Step 6: Have a check to ensure all lost data have been recovered.
3/27/2019 3:00:21 AM • Seagate... • Answered on Mar 27, 2019
Seagate backup plus is beeping and will not pull up on computer?? Yes when i plug in my hard drive, nothing pops up, but hard drive is flashing and making a beeping sound. HELP?
Could be a lost boot sector. Download Testdisk and use it to recreate the boot sector.
2/21/2019 8:39:14 AM • Seagate... • Answered on Feb 21, 2019
Computers & Internet Logo
7 questions posted
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Seagate Computers & Internet
Most Popular Question
recently received seagate 500gb external
  • Computers & Internet
