20 Most Recent Chamberlain 3/4-HP Whisper Drive Plus Evercharge Standby Garage Access System Questions & Answers
There are screws on the unit to adjust the opening and closing tension and place it stops. They are probably set for the previous installation and need to be adjusted for yours.
Chamberlain... | Answered on Dec 30, 2017
There should be a battery on your wall unit that needs replacement. God bless your efforts.
Chamberlain... | Answered on Sep 24, 2017
Change battery , not change battery the unit will not operate if there is a power failure.backup operation. 5 years is a long time on a disposable battery.
Chamberlain... | Answered on May 18, 2017
Check that the wheels and bearings are turning freely and that the door is not cocking to one side when closing. If the wheels are catching because of bad bearings, because the tracks are out of true or because the door is not staying straight in the tracks, the motor thinks that the door is hitting a car or a person and reverses. One thing to try: disengage the motor and try moving the door through the full traverse. Most automatic doors have a pull-cord that disengages the door from the motor. CAUTION: You may need a friend to help with the door, because it could be surprisingly heavy,.
Chamberlain... | Answered on May 01, 2017
It could be as simple as a drive motor force adjustment...
(you will have to get out the instruction manual)
Most likely your balance spring... one has failed
look over your springs very carefully... if one has shattered your counter-weigh is only lifting HALF the weight of your door.
Most garage doors need to be fairly NEUTRALLY BALANCED for the best, longest and reliable use.
Routine lubrication of the springs can add decades of useful life to your springs... CHATTERING Springs make a lot of noise and will soon shatter (break).
Sears makes house calls...
but they try to sell openers... you don't need.
https://www.bing.com/search?q=overhead%20garage%20door%20service&qs=n&form=QBRE&pq=overhead%20garage%20door%20service&sc=8-28&sp=-1&sk=&cvid=10E42AB45BFC41CC8E82D92DA893AB36 Sears Online In Store Shopping Appliances Clothing More
Chamberlain... | Answered on Oct 14, 2016
Adjust the position of the door by using the black and purple buttons. Black moves the door UP (open) and purple moves the door DOWN (close)
Setting the up position: 1. Press and hold the black button until the LED starts flashing slowly, then release. 2. Push and hold the black button until the door reaches the desired UP (open) position 3. Push the door control or programmed remote control. This sets the Up (open) position and begins closing the door. 4. Immediately when the door begins to close press and release the black or purple button. This will stop the door Setting the Down position: 5. Push and hold the purple button until the door reaches the desired DOWN (Closed) position. 6. Once the door is closed, If there appears to be too much pressure on the door, you may toggle the door back and forth using the black and purple buttons to reach the desired closed position. 7. Push the door control or programmed remote control. This sets the Down (closed) limit and the door should open.
Chamberlain... | Answered on Aug 04, 2015
as long as garage door is powered(plugged into outlet), then with a removed battery backup or a bad backup battery, the unit will beep to alert you to the issue. replace the backup battery with a new/good one.
Chamberlain... | Answered on Jul 11, 2015
check connections, check for correct polarity, replace lamp
Chamberlain... | Answered on Jan 20, 2015
U need to check the safety sensors. There may be a blockage in front of them... or one or both sensors have gone bad. Make sure the wiring from the sensors is complete to the opener unit first. There should be led lights on the sensors to indicate if they are functioning. One thing you should do is read your owners manual. If you can not locate it check online for a copy or reach out to the manufacturer since this is a safety issue they should be willing to help you. When it comes to solving issues we tend not to take the time to read things first. I even do it myself. I have had this problem and had to press the open/close switch until the door was fully closed. Most types of safety sensors are available online or in the big home repair retailers. Good luck
Chamberlain... | Answered on Nov 26, 2014
if you are using the new florescent bulbs they don't always seat deep enough. Unplug the opener remove the bulb in the bottom of the socket there's a metal tab use your finger or a small screwdriver and bend/lift the tab up a little bit. this should fix your problem
Chamberlain... | Answered on Aug 06, 2014
MANUALS ARE AVAILABLE IN PDF FILE AT CHAMBERLAIN.COM
THEY HAVE A VERY GOOD TROUBLESHOOTING SECTION
HOPE THIS HELPS
Chamberlain... | Answered on Aug 03, 2014
Chamberlain 3/4-HP Whisper Drive Plus Evercharge Standby Garage Access System Logo
Popular Tags
61 questions posted
Top Chamberlain Building Materials Experts
Joseph Hoffmann
liveone15
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
View Most Popular
  • Chamberlain Building Materials
Most Popular Question
beebing sound coming from unit
  • Building Materials
