20 Most Recent SMC EZ Switch SMC-8024L2 24-Port Gigabit Questions & Answers
Looks to me like they never implemented the serial port. The used unit I just obtained has no signal on the serial console pins and no SMC documentation beyond plugging it in appears to exist. Likewise with TELNET access.
However you can reset the switch to factory defaults with the following procedure from a pop-up window off the login page. It worked for me.
If you have forgotten the administration password you can return the Switch to its factory default state by doing the following:
1) Remove the power cord from the back of the Switch.
2) Remove all cables from the front-panel ports.
3) Connect port 1 to port 2, on the front panel, using a standard network cable.
4) Reconnect the power cord to the rear of the Switch.
5) Wait at least 40 seconds before disconnecting port 1 from port 2.
After completing this procedure, the password will be 'smcadmin' and the network address will be returned to the default; 192.168.2.10/24.
SMC EZ Switch... | Answered on Aug 14, 2013
There suppose to be a reset button on it mainly on the back of it
SMC Computers &... | Answered on Apr 23, 2019
different USB port. There are usually 3 or 4 of them. If you can, format the USB drive (if you have nothing on it or already have copies of what is on it). It will take 10 seconds, but will wipe all data. It should be recognized then.
SMC Computers &... | Answered on Apr 11, 2019
look for a windows xp driver file on the included program compact disc that may need to be installed before you use the included program.
SMC Computers &... | Answered on Mar 05, 2018
Ask a question.
SMC Computers &... | Answered on Mar 09, 2015
The question doesn't make sense but I'll assume you mean,
How fast is it.
It's set by the IEEE standards.
IEEE802.11
Look for eg. 802.11n
The letter at the end will give you an idea of it's speed.
N is current standard
AC is the most up to date
a & b are old standards
See http://en.wikipedia.org/wiki/IEEE_802.11
Cheers
Trevor
SMC Computers &... | Answered on Sep 09, 2014
Hi,efault
U need to isolate the problem first.
Check if the wireless drops on all devices or only on one particular device.
If it occurs on only one particular device,the problem is with the wireless adapter of that advice..
If it happens on all the devices then the problem is with wireless router
For that
Check for the wireless interference . Avoid having cordless phone base near the router.
Also try changing the wireless channel of the router To 1,6,11
U can do this by logging on to the router set up page of your router
To Find the address of your router,type ipconfig /all in the command prompt.Look for the Default gateway address and type it in the address bar.U will find your Router set up page..and u can change the wireless channel there
SMC Computers &... | Answered on May 14, 2014
Why is this posted in Networking? Solaris 4x4 650 cc quad bike. Tune up specs are required has nothing to do with Computers/NETWORKING
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_d799f810c7212a78
SMC Computers &... | Answered on May 11, 2014
SMC EZ Switch SMC-8024L2 24-Port Gigabit Logo
Popular Tags
2 questions posted
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
EZ SMC
  • EZ SMC
Most Popular Question
cannot log into smc8024l2
  • Computers & Internet
