I somehow managed to block four channels. I get all other channels. (Those channels I don't receive...
(More)
I somehow managed to block four channels. I get all other channels. (Those channels I don't receive (cable connection without a cable box) show a fuzzy black and white screen which suggests the tv is receiving all necessary signals.) The four I can't get now have a black screen. I do get the small info box at the top of the picture. I've tried seemly every menu option and combination. Is there a way to re-set the tv or remote?
I can't get my direct tv remote to work with my Polaroid FLM-3201 tv. I've gone through all of the...
(More)
I can't get my direct tv remote to work with my Polaroid FLM-3201 tv. I've gone through all of the codes listed in Direct tv's set-up. Any ideas or suggestions?
when I plug it in it causes buzzing/humming sound and flips the breaker. Already tried using a...
(More)
when I plug it in it causes buzzing/humming sound and flips the breaker. Already tried using a different power cord (from t.v to outlet) and plugging it into different outlets w/same result.
was turning off tv, it shocked me now i can turn it on but it goes to channel 4 no volume control...
(More)
was turning off tv, it shocked me now i can turn it on but it goes to channel 4 no volume control and no use of controls other than power button
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
