FixYa.com
IBM 0037A04 Multimedia Projector
All Products > IBM > Multimedia Projectors
Problems with IBM 0037A04 Multimedia Projector?
Search inside IBM 0037A04 Multimedia Projector Knowledgebase
Troubleshooting and Support
Solved Problems for IBM 0037A04 Multimedia Projector RSS Feed Post a New Problem
How do I redirect the output of my PC...
How do I redirect the output of my PC laptop to the projector?
1 Solution
How do I adjust the frequency for an...
How do I adjust the frequency for an external monitor (projector)?
1 Solution
Projection Problem with Toshiba TLP 261
When the projector is turned on, it displays the default screen. In the lower left corner the display is red. Adjusting...
1 Solution
Epson EMP-82e locked out
One of our staff turned off the projectors power. He then proceeded to input the wrong security code and the projector...
1 Solution
Connecting Sky TV to my projector
I am finding it hard to connect my sky tv to my projector, which cable do i need.
2 Solutions
green tint
I just purchased an epson powerlight s1. All the highlights are green. I tried adjusting the color and tint, but nothing...
1 Solution
how fast will you get this question?
Hi I am sitting in the hotel conference room and my computer screen won't show up on the projector. I've checked the...
2 Solutions
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC · Mac
TypeDLP Projector
Form FactorPortable
Display TechnologyDLP
Image Brightness1100 ANSI lumens
Contrast Ratio1800:1
Max Resolution (Native)1024 x 768
Image Aspect Ratio4:3 (Standard)
Image Size (Diagonal)26 in. - 200 in.
Screen Distance.23 ft. - 25.79 ft.
Color Support24-bit (16.7M colors)
Max Resolution (Interpolated)1280 x 1024 (SXGA)
Synchronization Range Horizontal15 - 90 kHz
Synchronization Range Vertical50 - 85 Hz
Technical Features
Audio OutputSpeaker(s)
Front Panel ControlsKeypad
Remote Control FeaturesLaser Pointer · Built-in Mouse
Interfaces
InterfaceUSB
Video Input4 Pin - Mini DIN (S-Video) · DVI-I · Composite Video
Lamp
Lamp TypeP-VIP
Light Source Life2000 Hours
Light Source Power200W P-VIP
Other Features
Special FeaturesOn Screen Menu · Keystone Correction · Key Lock
Speakers Output.5 W
Projection MethodRear · Front
Standards
Analog Video FormatNTSC · PAL · SECAM
HDTV Formats720p · 1080i · 480p · 480i
Warranty
Warranty3 Years, 90 Days On Lamp
Dimensions
Depth6.4 in.
Height1.9 in.
Width7.2 in.
Weight2.4 lb.
IBM Contact Information
Main support number1-800-IBM-4YOU / (1-800-426-4968)
Email supportaskibm@vnet.ibm.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
