20 Most Recent
Rockford Fosgate Power T3002 Car Audio Amplifier Questions & Answers
Amp blowing fuses
Check for short circuit in speaker connections or the connecting wires unless some internal defect has occurred.
Water spilled on rockford t3002 now protect light
All depends, when amp is connected does it blow the fuses, if not, it maybe repairable, But its a long process. when your amp is on and has water spilt onto it, the water inside the amp evaporates and gets into every nuck and cranny due to the amp heating up when powered on. you need to strip amp down to bare basics and completely dry the circuit board and all compnents one by one, hense a long process. Best thing to use is a hair dryer. get the hair dryer into every nuck and cranny, into the connectors, basically everything. once done. put back together and try it then. i had a home amp with water damage and fixed it this way.
I have a t3002 going
It could possibly be a bad ground. I ran in to the same problem the other day, but I wasn't driving. Started my car and everything seemed to work ok then all of sudden nothing. I checked all the voltages when the car is turned on, remote turn on (should have more than 11v), power cable to chassis ground (12+ V), they were all there. Then I finally checked the ground just moving the connection turned it on and then off. This occured repeatedly, then I disconnected the ground and then reconnected, now amp is running like a champ.
Amp wont turn on and theres power to the amp and
check the ground to the amp. then check the remote wire. make sure u have the sub option on ur stereo turned on. if all is wired up correct an u do not have the subs turned on in ur stereo settings then the stereo will not send power through the remote wire an therfore your amp will not power on.
2 12 p3d212 2 ohm hooking up to a rockford
Hello a_brake11,
The P325.1 is relatively small to power a pair of P3's. You'll only get 325 watts RMS at 2 ohms (162.5 watts per sub). The P3's power range is from 100-500 watts, so they will work, but don't expect them to be really loud.
For best power, your subs should be wired with the voice coils in series and then the 2 subs paralleled to the amp resulting in a 2 ohm load.
Hope this helps.
I have a Rockford Fosgate 1500 BD amplifier and terminals for the power cable will not loosen or tighten how do I fix it
First off will the fastener turn ? If not try using a bit of wd-40 and letting it "soak" for a little while . Also be sure you are using a good proper sized Phillips screwdriver . If the fastener still won't turn try using a can of "computer duster " inverted so the liquid comes out , note this will be well below zero degrees , and freeze the screw head , then try turning . If the fastener is stripped and the ttol slips you will have to remove the amp cover and grip it with a pair of vise grips ,pliers or a flat blade screw driver .
