FixYa.com
Bugaboo Frog - Red Stroller
All Products > Bugaboo > Strollers
Problems with Bugaboo Frog - Red Stroller?
Get a Replacement
Troubleshooting and Support
Solved Problems for Bugaboo Frog - Red Stroller RSS Feed Post a New Problem
broken brake cable
Hello, Our Bugaboo Frog was moved out of the way by someone, while the brake was fully on. The brake no longer works...
3 Solutions
Bugaboo Frog Foam Handle ripped
Hi, How can I fix the foam handle on my Bugaboo Frog stroller? It has a half inch tear and I would like to prevent it...
1 Solution
found a bugaboo
Hi I was wondering if there was a bugaboo frog repair service that I can bring my stroller to.
1 Solution
i don't know how to
i don't know how to change my bugaboo frog from the chair to the bassinet?
1 Solution
Bubaboo Frog Tilt Wheel
I have this Bugaboo Frog, I recently noticced one of the big wheels is tilt, the uper side of the wheel is nearer to the...
1 Solution
tilting bassinette
When I position the bassinette on the frame, there is an obvious tilt.  Works OK when baby is facing me, but when...
1 Solution
Unfolding the Chassis - Handlebar Loose
I just purchased a Bugaboo Frog. In unfolding the chassis, I follow the instructions below. After I hear the click on...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Bugaboo Frog - Red Stroller RSS Feed Post a New Problem
can't get the seat off!!
Hello, Someone at my sons' nursery put my bugaboo up the other day and said they had trouble doing so. When I got my...
Post a Solution
HARNESS TOO BIG
I just changed my frog from the basinett to the seat, but the arm part of the harness is too loose and it is pulled as...
Post a Solution
bugaboo matirial
is there somewhere that i can buy new matirial for my bugaboo frog? i bought a used one and would like to change the...
Post a Solution
My bugaboo wheeled board needs
My bugaboo wheeled board needs to be re attached but have lost the instructions can you please tell me how i can re...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeStroller
Number of SeatsSingle Seat
Max Weight Capacity44 lb.
Harness Points5-Point
Recline FeaturesReclining Back (3 Positions)
Other Features
Safety FeaturesWheel Suspension
Storage FeaturesLower Storage Basket
Handle FeaturesReversible Handle
Convenience FeaturesWashable, Removable Canopy, Optional Car Seat
Structure
Frame MaterialAluminium
Dimensions
Weight16 lb.
Folded Width20 in.
Folded Height35 in.
Warranty
Overall Warranty2 Years
Bugaboo Contact Information
Main support number18004602922
Email supportservice@us.bugaboo.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
