20 Most Recent
Activision Call of Duty: Black Ops - Prestige Edition for Xbox 360 Questions & Answers
Im just curious on is
Prestiging is only for show. It does not unlock any abilities to be stronger, faster, quicker etc. However, it does unlock certain symbols that you can add to your emblems and it unlocks certain titles you can buy with COD points. There is no upper-hand that you will have if you prestige.
Can't see video audio works
Make sure the cable with the yellow at the end is plugged into your tv, and if it is, unplug it and plug it back in.
I am having a problem.
Direct3D 6? Wow, the game must be way older than your computer. You probably installed DirectX 10 or later. There were major changes after DirectX 9. The software routines to manage graphics hardware acceleration through DirectX 10 or newer are probably very different from DirectX 6, so the game's graphic controller interface can't find them.
Try going into the game properties (right-click on the main executable file and select Properties from the pop-up menu).
Set it to run in XP compatibility mode and see what happens.
Check to see if the game has the option to run without hardware acceleration. If this provides acceptable performance, that is your answer.
If necessary (and if Microsoft still makes it available), try installing DirectX 6. Vista may snag on it and make you remove it and reinstall a newer version, but it's worth a shot if the other fixes don't work.
Yo dudes I play call of duty modern warfare 2 and
This is hard to answer because i dont know your style of play but if you dont care to be called a noob and such i would go with an asuslt rifle such as the tar-21 or scar-h with the grenade launcher and a shotgun as your secondary or akimbo pistols. This combo willget you many kills but you will be yelled at lol
