20 Most Recent MSI INTEL G41 INTEGRATED VGA-MATX 2DDR3 MAX 8GB GETH (G41MP23) Motherboard Questions & Answers
SOURCE:No boot No video on new built pc with a msi motherboard a55m-p33 amd, three beeps at start up.
Hello here is the homepage:
http://www.msi.com/product/mb/A55M-P33.html#/?div=Driver&os=Win8%2064
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
Tree beeps means you have a ram module failure, or not inserted correctly.
This mainboard uses DDR3 ram, up to 16 gb.
Try to start with only one module at the time.
Try also to check the manual:
http://www.msi.com/product/mb/A55M-P33.html#/?div=Manual
MSI INTEL G41... | Answered on Jan 13, 2015
How to Fix a Code 43 Error
  1. Restart your computer if you haven't done so already.
    There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
    Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
    Undo the change if you can, restart your PC, and then check again for the Code 43 error.
    Depending on the changes you made, some solutions might include:
  3. Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a possible solution to a Code 43 error.
    Important: If a USB device is generating the Code 43 error, uninstall every deviceunder the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
    Note: Properly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
hope this helps
MSI INTEL G41... | Answered on Sep 17, 2012
1.Release the MEMORY MODULE ( RAM )
2.Cleanup the connector Module with a dry tissue or white clean paper
3.Put it back on
Note : If you have double RAM >> try using patially...
akee_akee@live.com
MSI INTEL G41... | Answered on Aug 16, 2011
Although I've got a different type of MSI but I have where the "official guys" say there should be: at the back of it, maybe you need to remove the battery and look there under "S/N: xxxxxxxx"
MSI Computers &... | Answered on May 11, 2019
that 1996 is not correct (its series name only)
MSI N1996 Motherboard P6NG Neo-Digital MS-7505
the bottom sticker on the mobo tells what it really is.
MSI motherboard, just bought ? used"?
ever see it work before.
did you go to msi.com and the manual on setups"?
are you using the onboard VGA port to a VGA monitor.
The monitor shows no signal means exactly that.
This motherboard has 1 power jacks, the big one 24 pins
and the 4pin at top left of the fan.
you must use PSU v2.2 or newer to get that 4 pin power.
covered on page 24 in your manual, here.
https://www.msi.com/Motherboard/support/P6NG_NeoDigital#down-manual
and CPU and fan, (correct)
and memory
and a power switch to the power switch jack.
next time post all stickers on mobo so we can see what it really is.
they made vast numbers of motherboards. a fact.
MSI Computers &... | Answered on Apr 12, 2019
Well, you could uninstall anything related to the sound device. If you can, I suggest using the sound driver provided by the manufacturer. Let me know how it went, thanks.
MSI Computers &... | Answered on Jan 26, 2019
Beeping mostly means it's trying to give an error code along. Listen to the amount of beeps and the duration of them. This is the error code that it tries to give on. Look up in the manual what the beeps mean and how to solve it.
MSI Computers &... | Answered on Jan 17, 2019
Cheers!!
Need to replace the display flex ribbon cable to solve the flickering and color lines problem. This cable gets damage over the time of long usage.
MSI Computers &... | Answered on Nov 20, 2018
Add more RAM memory.
MSI Computers &... | Answered on Nov 10, 2018
No update will increase the speed.
There may be drivers from the keyboard manufacturer that need to be loaded in Windows.
MSI Computers &... | Answered on Nov 01, 2018
MSI INTEL G41 INTEGRATED VGA-MATX 2DDR3 MAX 8GB GETH (G41MP23) Motherboard Logo
7 questions posted
Top MSI Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • MSI Computers & Internet
Most Popular Question
boot problems
  • Computers & Internet
