20 Most Recent Dell Inspiron M5030 Laptop Questions & Answers
Log on to Dell Support with another computer. Enter service tag and follow instructions from there.
Dell Inspiron... | Answered on Nov 03, 2017
Q: So what version of Windows is this? Assuming it's Not Linux?
Windows 10: Use this URL. I recommend Method 3 the on-line forgot password. the only bad thing is this will also reset your hotmail address password as well. But it worked well for me.
https://www.top-password.com/knowledge/reset-windows-10-password.html
Dell Inspiron... | Answered on Jun 13, 2017
It really depends on the model number as methods vary. What is the model number?
Dell Inspiron... | Answered on Apr 17, 2017
There are three options.
1/ Use correct password.
2/ Contact hdd manufacturer who can remove the password but will erase all data and charge for the service.
3/ Purchase a new hdd and reload your OS. Then you can restore your backups.
Dell Inspiron... | Answered on Dec 20, 2016
It could be the graphics processor is having troubles. Try updating the graphics drivers.
Dell Inspiron... | Answered on Oct 19, 2016
try to install the drivers melinda . look for the offline installer of driver pack to the internet and download it. run it to your computer
Dell Inspiron... | Answered on Sep 29, 2016
Step 1:
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove new hardware If any new HARDWARE has been recently added to the computer, remove that hardware to make sure it is not the cause of your issue. If after removing the new hardware your computer works it's likely the computer is either not compatible with the new hardware or a system setting needs to be changed to work with the new hardware device. Remove any disks or USB devices Remove any disks, CD's, DVD's that are in the computer and if any USB devices (Ipods, drives, phones, etc) are connected disconnect all of them as well. Reboot the computer and see if anything changes. Disconnect external devices. Remove everything from the back of the computer except the power cable. Turn on the computer and see if it beeps normally. If the computer has never beeped keep the monitor or display connected to see if any change occurs. Check all fans Make sure all fans are running in the computer. If a fan has failed (especially the heat sink fan for theCPU) your computer could be overheating or detecting the fan failure causing the computer not to boot. Check all cables Verify that all the cables are properly connected at that there are no loose cables by firmly pressing in each cable. All disk drives should have a data cable and power cable connected to them. Your power supply should have at least one cable going to the motherboard. Many motherboards may also have additional cables connected to them to supply power to the fans. Disconnect all expansion cards If the above recommendations still have not resolved the irregular POST, disconnect the riser board (if applicable) and each of theexpansion cards. If this resolves the issue or allows the computer to POST connect one card at a time until you determine what card is causing the issue. Disconnect all drives If you were unable to determine by the beep code what is failing or do not have a beep code disconnect theIDE, SATA ,SCSI or other data cables from the CD-ROM ,Hard Drive and Floppy Drive from the Motherboard. If this resolves your irregular POST or generates error messages re-connect each device until you determine what device or cable is causing the issue. In some situations it can also be a loose cable connection that causes the issue. Remove the RAM If you continue to to receive the same problem with all the above hardware removed, disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue. Re-insert the memory into the same slot. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick. Try one stick of memory in each slot. If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify what stick of memory is bad and replace it. If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard. Power cycle the computer In some situations a computer may have power related issues often caused by either the power supply or the motherboard. To help determine if this is the cause of your issue try turning the computer on, off, and back on as fast as possible, making sure the computer power light goes on and off each time. In some situations you may be able to temporarily get the computer to boot. This should only be used as a temporary workaround if you're able to get this to work. Often this is good for users who may have not done a backup and need to get the computer up one more time to copy files before starting to replace hardware. Disconnect and reconnect the CPU For users who are more comfortable working with the inside of their computer or who have built their computer one last recommendation before assuming hardware is bad is to reseat the CPU by removing it and putting it back into the computer. Bad motherboard, CPU, RAM, or power supply If after doing all of the above recommendations you continue to have the same issue unfortunately it is likely that you have badMotherboard, PSU, CPU, orRAM. The next step would be either to replace these components or have the computer serviced. If you plan on doing the repairs yourself or you are a repair shop it is suggested that you replace the Motherboard first, RAM, CPU, and then power supply in that order or try swappable parts from other computers.
Dell Inspiron... | Answered on Jan 28, 2016
Your PC is broken and needs repaired.
Dell Inspiron... | Answered on Nov 02, 2015
Trouble code 7. CPU cache test failure.
Keyboard is worn out. You need to have a new keyboard installed on your laptop.
You have a bad keyboard
Dell Inspiron... | Answered on Aug 18, 2015
Most propably its the went bad try to connect to external screen
if it work then its then you have to replace it if the external one doesnt work it meas the the video card is bad.
Regards
Dell Inspiron... | Answered on Jun 10, 2015
LCD video cable. Plus, to connect and activate an external monitor, you click Fn + F2, not F8.
Purchase a new hdd and install your OS on it. You will still have a cheap deal even though it is possibly stolen!
Dell Inspiron... | Answered on Feb 20, 2015
sounds like you processor is running hot. clear the dust and dirt with a vacuum cleaner from the vents where air escapes from the laptop.you can also buy compressed air to help blow out the vents.
Dell Inspiron... | Answered on Jan 11, 2015
If you have a damaged locking clip you have two choices. Either repair it of replace the socket assembly.
Dell Inspiron... | Answered on Dec 06, 2014
Let me know the issues with the Dell Inspiron M5030 laptop and then I can check and suggest what needs to be done.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Dell Inspiron... | Answered on Sep 18, 2014
Dell Inspiron M5030 Laptop Logo
294 questions posted
Clive
Clive
Alun Cox
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
39 feedback sound coming speakers dell
  • Computers & Internet
