20 Most Recent
Travel Smart Lectronic Smart LS1ADR All-In-One Adapter with Built-In USB Port - Ret Questions & Answers
Conair problems
Hi Anonymous! A couple of questions:
- I hope you will forgive me asking the obvious, but did you ensure the location selector on the side is firmly locked in the UK position? Have you tried (while it's unplugged) sliding it from UK back to US and then back to UK?'
- Does this happen when using the USB alone or does the adapter behave this way when using the power itself (i.e. shaver/dryer/etc.)?
Also, and I imagine you already know this, but remember that the AC portion of this product does not convert electrical voltage. You will require a converter or transformer for your single-voltage appliances. If the appliance has an internal 110/220 (60Hz/50Hz) switch, then you are fine.
If you have already tried these things and the adapter still is malfunctioning, you may want to see about warranty exchange.
Hope this helps.
I have a crane 181 with a nayax reader. It's only flagging 11 MDB codes. Any answer as to why? Firmware has been up
Without more information, it's challenging to determine the exact reason why your crane 181 with a Nayax reader is only flagging 11 MDB codes. However, here are a few potential reasons why you may be experiencing this issue:
- Compatibility: Not all vending machines and readers are compatible with each other. Make sure that your Nayax reader is compatible with the Crane 181 vending machine.
- Reader configuration: Check the configuration settings of your Nayax reader to ensure that it is set up correctly for the Crane 181 vending machine.
- Communication issues: Check the communication between the Nayax reader and the vending machine. If the communication is interrupted, it may not flag all the MDB codes.
- Faulty Reader: Your Nayax reader may be faulty or damaged. In this case, you may need to replace the reader or have it repaired.
- Firmware: Even if your firmware has been updated, there may still be compatibility issues between the Nayax reader and the Crane 181 vending machine. Double-check the compatibility of your firmware with both devices.
It's best to contact the manufacturer of your Crane 181 vending machine and Nayax reader to get specific support for your issue.
What services does your web agency in Linkoping offer?
We offer a variety of services, including web design https://webbson.se/linkoping web development, e-commerce solutions, mobile application development, digital marketing and search engine optimization (SEO). Our goal is to help companies and organizations in Link?ping with everything related to their online presence.
The power devices that Cisco Catalyst 2960 Series Support?
The Cisco Catalyst 2960-48PST-L can support 48 PoE ports with total PoE power output capacity at 370W. Taking advantage of Cisco Catalyst Intelligent Power Management, the Cisco Catalyst 2960-48PST-L configuration can deliver the necessary power to support 24 ports at 15.4W, 48 ports at 7.7W, or any combination in between.
The Cisco Catalyst 2960-24PC-L can support 24 simultaneous full-powered PoE devices at 15.4W for maximum powered-device support.
The Cisco Catalyst 2960-24LT-L can support eight PoE devices at 15.4W
Cisco Catalyst 2960 Switches for the details
