20 Most Recent
Tripp Lite SRCOOL12K Air Conditioner Questions & Answers
My Tripp Lite SRCOOL12K led
Hello, Ron.
P1 is a water tank error. Could be an alert that the internal bucket is full of water. Drain with a long tube and gravity.
If still a problem after you've emptied it, make sure that the reservoir is positioned correctly. Also, check the timer controls.
Hope this helps.
Srcool12k coolant replacement
Support for SRCOOL12K Tripp Lite Look on this page. Coolant has to escape from a leak somewhere in the tubing. Before it can be replaced, the leak must be located and repaired. Then a vacuum has to be drawn for an hour or so to remove any air and moisture that has entered the system. Unless you posses all the tools, the silver soldering torches, vacuum pump, gauge manifold and hoses as well as a scale to weigh the amount of freon to put in or a clamp on AC ammeter to measure full load current, you should leave all that to a pro.
Hello
How can I disassemble my
Why do you need to dismantle this? Some of these types of cooler do not have replaceable parts inside. They are usually classed as a "Throw away" machine. It is often easier and cheaper to replace it than repair it.
4/9/2024 1:31:04 PM •
Heating &...
Answered
on Apr 09, 2024
Homebasix Olliscating parabolic heater how to reset
o reset your Homebasix Oscillating Parabolic Heater, follow these steps:
Unplug the heater from the power source.
Locate the Manual Reset Button on the heater. It's usually a small button or switch.
Use a fireproof, non-conductive rod (such as a wooden stick or plastic tool) to press the Manual Reset Button.
After resetting, plug the heater back in and check if it functions properly.
Remember to ensure that there are no flammable objects within 3 feet of the heater and that it is placed on a stable surface.
4/7/2024 11:23:24 AM •
Heating &...
Answered
on Apr 07, 2024
