20 Most Recent Microsoft Sharp Kin 2 Standard Battery 1100 mAh Questions & Answers
HI,
it looks like you will need to change the screen ,
sorry,
daniel
https://www.rylwy.com/carbon-antenna
Microsoft Sharp... | Answered on Jan 04, 2018
Look at your charger connection and plug and make sure they are clean of dust/dirt...etc.
Microsoft Sharp... | Answered on Nov 30, 2017
Its due to the fact that you probably have overcharged the battery. Hence the reason when you get a new phone it says on the "to do"list to let it charge for a full 24 hours and then use the phone. Most people disregard that message and use the phone right away. BUT thats not what your technically supposed to do. Your SUPPOSED to let it charge fully then continue use, due to the fact that when you do end up charging it at night or whenever after having it for a little bit the battery can either ,"A": Blow up within the phone itself, or "b" will not hold a charge whatsoever or "c"do the whole 00 thing. So lesson learned, Let your phone charge thoroughly.
Microsoft Sharp... | Answered on Feb 19, 2011
What every you take out of the battery you need to put back in (plus the losses), the amount of watts you need is proportional to the AC load the equation I use is array size in watts X peak sun hours divided by 2 or .5 the .5 is the losses in the system also your inverter should be matched to the batteries as a rule you should not draw anymore than 100 amps from the battery .
Electronics -... | Answered on Nov 09, 2018
model.shiny 850 va is problem on/off. main switch.
switch on/off good position.
inverter everything on position
please solution?
Electronics -... | Answered on Nov 02, 2018
Try using google translate. Its on the internet. German to English.
Electronics -... | Answered on Oct 30, 2018
'Pro 2'. What is that .........
Electronics -... | Answered on Oct 29, 2018
Not at all, pls check this one: Amazon com MASKELENA Solar Charger Solar Power Bank 12000mAh External... No more than $30
Electronics -... | Answered on Oct 22, 2018
Find the exact model number and do a search for that and manual in google. Follow the instructions in the manual.
Electronics -... | Answered on Oct 20, 2018
Microsoft Sharp Kin 2 Standard Battery 1100 mAh Logo
7 questions posted
Top Microsoft Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you a Microsoft Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Microsoft Electronics - Others
Most Popular Question
brand new kin 2
  • Electronics - Others
