20 Most Recent Dyson DC33 Bagged Upright Vacuum Questions & Answers
Look to see if it has a switch on it that says floor /carpet. as it will raise the head enough for more clearance under it.Don't allow it to keep slipping, it will burn up the rubber band that drives the brush.
Dyson DC33... | Answered on May 13, 2017
Hello, this is Ava with Think Crucial.
Please refer to the link below for the Dyson DC33 online manual:
https://www.dyson.com.au/medialibrary/Files/Dyson/Support/downloads/ANZ/Floorcare/User%20guides/DC33_OPMAN_ANZ_MUFL24112011.pdf
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dyson DC33... | Answered on Feb 17, 2017
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dc33
Ava B.
Dyson DC33... | Answered on Nov 24, 2016
The brushroll is turned on and off br rotating the round lever
Dyson DC33... | Answered on May 07, 2016
contact dyson tech support
Dyson DC33... | Answered on Jun 10, 2015
With a small torx driver (not the folding kind, the screw driver kind) and some patience, the belts can be replaced pretty easily. They run about 10 bux for both (you may as well change both). Dyson, like most manufacturers, makes it seem difficult in the hopes that you'll send it back to them for repair, where they will most likely sell you the whole clutch assembly because its easier to replace than fiddling with belts.
Dyson DC33... | Answered on Mar 22, 2015
Replace both filters and clean out the dust bin and cyclone chamber real well.
Dyson DC33... | Answered on Mar 14, 2015
your fillter needs cleaning out
Dyson DC33... | Answered on Feb 20, 2015
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC33. When the vacuum is switched on and standing upright, suction will always be diverted automatically to the wand and hose for above-floor cleaning. When you recline the machine into the normal vacuuming position, the suction should be transferred to the cleaner head. Make sure the brush control is set to 'Carpets', as the brush bar will not rotate when it's set to the 'Hard Floors' position.
If it doesn't seem to be picking up as well as it should be, we'd appreciate the opportunity to talk you through some simple troubleshooting checks when you have your machine to hand. We'll be able to ensure everything is working correctly - and if a replacement part or repair is needed, we can also confirm if this is covered under your Dyson warranty.
You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). We'll look forward to speaking with you.
Dyson DC33... | Answered on Feb 12, 2015
Needs a new battery.Thats what it sounds like...Your battery is.not working correctly. Replace the battery and it will more than likely solve your problem...Hope I Help..
Ellen
Dyson DC33... | Answered on Dec 18, 2014
Is it possible that you have accidentally changed the brush control setting? I say this because it happened to me and I thought it had broken. I must have caught the dial with my foot! Here a link that might help:
Dyson DC33... | Answered on Aug 31, 2014
Hi, it's Jeremy from Crucial Vacuum.
If your DC33 has no suction there are a few potential solutions you should try. You can check the hose and canister to make sure nothing is lodged in them. If there is nothing lodged in them and that does not work the problem could be related to your filter. Filters should be replaced every 3 to 6 months for optimal performance.
You can purchase direct your replacement vacuum part needs from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Dyson DC33... | Answered on Jul 17, 2014
DC33 is suitable for cleaning hard and carpeted floors. It includes a brush control system which allows you to shut the brush bar off when cleaning hard floor surfaces. It's worth checking that the brush control is set correctly - it's possible it may have been inadvertently set to 'Hard floors'. For the brush bar to rotate, it must be set to 'Carpets':
It's also important to note that the brush bar will not rotate when the vacuum is standing upright, so make sure you recline it into the normal vacuuming position before testing it.
If this doesn't resolve the issue, please turn off and unplug the machine, then check that there are no obstructions in the cleaner head which could be jamming the brush bar. Remove any threads or hair around the brush bar, as these can affect the performance.
If you'd like further advice from our experts after you've given this a try, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). We can take you through some diagnostic checks to determine what may be causing the issue. If a repair or replacement part is needed, we can also confirm if this is covered under warranty.
Dyson DC33... | Answered on Jun 05, 2014
Dyson DC33 Bagged Upright Vacuum Logo
121 questions posted
Top Dyson Vacuums Experts
AskDyson
AskDyson
Etronix
Level 1 Expert
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Dyson Vacuums
  • Dyson Vacuums
Most Popular Question
dyson dc33 isnt working correctly s not
  • Vacuums
