20 Most Recent
Sharper Image MC502 System Questions & Answers
Unknown Disc Format
This could be due to too much dirt on the lens of the player. Or it some cases damage inside the unit so the lens won't move, or damage to the lens itself.
You're best option is to remove the top cover to see the state of the workings. Then to spray the lens with Servisol Video 40 to clean it.
If that doesn't work it could be the lens is scratched.
Lost remote
You should buy. Each remote come with instractions how to program it.
Also you can ask on the store.
Wireless headset
You do not need an amplified signal. The signal is amplified in the head set. You may need to change the audio settings on the TV change from internal speakers to external amp and/or change from variable to fixed audio out.
Replacing batteries in Sharper Image wireless specker
Usually, you can use the + and - signs within the battery compartment to guide your placement of the batteries. But you want to make sure that the batteries are compatible with your speakers, so calling Sharper Image to verify this would be a good move.
Thank you
My sharper image touch mp3 player won't play .avi files.
The problem is that the player of this MP3 has a corrupted program. If this device could play .avi and .mp4 before, you need to contact the manufacturer and have them reloaded the program.
But if you haven't tried playing .avi and .mp4 file format before, then refer to the user manual to verify it this device supports those video file format.
Thank you!
