20 Most Recent
SmartDisk FlashTrax MP3 Player Questions & Answers
When I load some mp3 files onto my FlashTrax, they
Hello
OK, i would firstly advice you to make sure that all the audio files you copy to the unit is actually .mp3 format. If the files is not in .mp3 format, the unit will sometimes give you this error message.
Kind regards
Andrea
11/25/2010 2:48:49 AM •
SmartDisk...
Answered
on Nov 25, 2010
I have a FlashTrax FTX40
Thank you for posting your question on Fixya! As you may your media player uses a hard disk as the primary storage device. The type is usually 2.5" SATA. From what you have described, the hard disk of the player is the source of the problem. The noises usually indicate a hard drive crash. Even though you can format the disk to get it back to normal, The only way to recover the data on it is to take it apart, get the hard drive out, hook it up to your PC and use a data recovery tool to recover the data. I usually use a software called data rescue PC to recover data from dead drives but its a bit expensive(Currently costs around 90$). To prevent this from happening in future always use the SD card option to store the files. Format the SD card using FAT32 and store your pics. I have been using my card formatted using FAT32 for almost 3 years now on various devices without a problem.
Let me know if you need more help.
Sai.
11/4/2010 4:45:18 PM •
SmartDisk...
Answered
on Nov 04, 2010
FlashTrax40GB
hi
try system restore on your pc and restore it to the last time your flashtrax worked ok
2/9/2008 1:09:14 AM •
SmartDisk...
Answered
on Feb 09, 2008
Smartdisk flashtrax player'
arcsoft media converter ,you can download a sample of this software from their website.it costs around 12.00 to upgrade so dvds can be coverted.it is very good------or mediacell mobile video converter,this is also free but linited use
2/8/2008 4:43:56 PM •
SmartDisk...
Answered
on Feb 08, 2008
Would like to change the format [MS-DOS [FAT32] on
Plug your device into your mac, open "Disk Utilities," located in the "Utilities" folder in the "Applications" folder. Once it is opened select your device in the list on the left side, Now click where it says "RAID," now change the "Volume Format" to MAC OS Extended(Journaled).
Hope this helps!
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
