20 Most Recent Intex 10ft X 30in Easy Set Pool Package Questions & Answers
What is the HP of an Intex 673R filter pump
It is a pump, only motors are measured in Horsepower. I would expect the HP of this above ground combined pump and filter is so low they would be embarrassed to state. It is measured in Gallons Per Hour flow rate. https://www.google.com/search?q=Intex+673R+pump+specs ..
1/27/2024 5:35:17 AM • Intex Pool & Spa • Answered on Jan 27, 2024
What does U16 mean on my intex hot tub
limited info generic answer u code doesnt show for intex their codes usually start with E this is a manual that has the trouble shooting on page 20 ------- https://www.manua.ls/intex/purespa/manual?p=1 --------- and pg 13 has the codes
7/25/2023 11:59:11 AM • Intex Pool & Spa • Answered on Jul 25, 2023
I wanted to know if when inflating my Intex pure spa it's normal for the bubbles to also go on ? I thought when attaching the inflation hose it would bypass them
Here's the manual with setup information...https://www.manua.ls/intex/purespa/manual?p=9MY bad you'll have to copy and paste the link. :(
6/30/2023 12:46:00 AM • Intex Pool & Spa • Answered on Jun 30, 2023
3answers
I have an e95 error code on my intex spar and it won't let me put the heater on
means temp to low and the last link is the answer from intex they stat to unplug system then replug but when the pump goes that causes same code since no water flow no water flow your pump has failed these pumps are a magnetic with a small ceramic rod to hold it in place the ceramic rod breaks and stops pump -- intex doesnt sell parts or replacement pump ---easy fix is to go to lowes they sell a brass rod about $4 or home depot and in welding isle is a package of brazing rods [[ brass ]] with a flux covering $ 10 dollars clean the flux off and measure rod about 3 inches is needed How to repair Intex PureSpa pump E90 Error 90 Intex Pure Spa E96 slow reset solution these links can assist http://www.intexcorp.nl/faqsup/pub/FaqSupportServlet?action=openFaq&qid=608&lst_prd=853&lst_subcategory=854&frmcontact=
3/11/2023 2:23:58 AM • Intex Pool & Spa • Answered on Mar 11, 2023
E 97 Dry Fire Protection Can I run the filtration and the bubbles or jets to solve the problem?
E 97 is an error code that indicates a dry fire protection system has been activated in your Intex Pure SPA. This means that the spa has sensed that there is not enough water in the system, and it has automatically shut down the heater to prevent damage. To solve this problem, you will need to add more water to the spa. Once the water level is above the minimum level required for safe operation, the dry fire protection system should reset itself automatically. It is not recommended to run the filtration and the bubbles or jets without enough water in the system as it can cause damage to the pump and other components. Therefore, make sure to add enough water before turning on any functions of the spa. Also, make sure to check for any other causes that may have led to the water level dropping too low, such as a leak or drainage issue. If you continue to experience issues, refer to the owner's manual or contact Intex customer support for further assistance.
2/27/2023 5:23:52 AM • Intex Pool & Spa • Answered on Feb 27, 2023
Intex Pure Spa reads code E97. How do I correct this please?
Question edited for clarity and typos. If alarm code E97 is displayed on the control panel, it means there is a heater fuse error. If alarm code appears on the control panel, unplug and plug back in the GFCI/RCD and test the GFCI/RCD to restart the system. If the problem persists, please contact a Intex service center for assistance.
What does code E97 on my spa mean? What should I do if ...
2/27/2023 12:18:51 AM • Intex Pool & Spa • Answered on Feb 27, 2023
Intex Pure Spa. I'm wondering if anyone has a wiring diagram for the base? Mice ate my base unit and I can't work out some of the wiring. Can anyone help please?
Question edited for clarity. 'make model (what it is) first 3 words Question moved from 'Pure Cameras'. Intex are pretty good with technical documents. 'Pure Spa' is the 'friendly name', but they all have model numbers. This https://intexfaq.ch/wp-content/uploads/2021/02/2021-SSN-Combo-Spa-28462-Control-Base-Repair-Guide.pdf Was found here. Click the IMAGES tab for lots more pictures. https://www.google.com/search?q=intex+pure+spa+wiring+diagram ..
2/9/2023 1:09:22 AM • Intex Pool & Spa • Answered on Feb 09, 2023
3answers
The plug on my intex hot tub trips when I plug it in
You have a short in the wiring.
1/8/2023 10:01:06 PM • Intex Pool & Spa • Answered on Jan 08, 2023
I have set my pool and chlorinator up it is brand new today it keeps reading code 92 but doesn't light up saying low or high salt. Is the chlorinator faulty?
Salt generators take, on average, around 24 hours between adding salt and the system realizing or analyzing the data. A code 92 usually means salt levels are too high, but not always. It is best to take a water sample to a pool store for analysis to truly determine if that's the case. If so, draining some water and adding fresh water are the only real ways to rectify the salinity. Best wishes and hope this helps.
12/19/2022 3:14:05 AM • Intex Pool & Spa • Answered on Dec 19, 2022
3answers
Intex pure spa motor isn't circulating water, but the bubbles work. What's wrong? I think I have tried everything. Help!
Probably bad control box for the jet motor/s if the motors are running could be bad pump or a pipe valve issue. Or is there a separate blower?motor that feeds the bubbles (air)
11/9/2022 2:30:10 AM • Intex Pool & Spa • Answered on Nov 09, 2022
3answers
My intex spa is reading 999 and won't cut on. This happened after a power outage
are you sure its not e99 water temp sensor because their is no 999 code for intex -----------turn off at gfi and unplug for about 5 minutes then plug back in unit some times glitches if code comes back same then notify intex [ good luck ] of code 999--any other code can be found in manual or online ----intex purespa code === ----
11/7/2022 3:34:14 PM • Intex Pool & Spa • Answered on Nov 07, 2022
2answers
Intex Purespa SB-H20: leak in top connector between spa control unit and tub.
Question edited for clarity, name of maker. Question moved from washing machines. For water rushing out, try and block from the other side so water doesn't reach the part you are undoing. Here is a parts diagram and all the washers and O-rings. Your local pool supplier probably carries them. https://www.pools.shop/en/intex-spare-parts/whirlpool-pure-spa-bubble-small-1 More here https://www.google.com/search?q=Intex+Purespa+SB-H20+parts ..
11/7/2022 3:29:44 PM • Intex Pool & Spa • Answered on Nov 07, 2022
Intex Spa impeller replacement
https://www.google.com/search?q=intex+purespa+impeller&sxsrf=AOaemvJ7l9-8AVGl07owxmONpRSihGlfAw:1633987545673&source=univ&tbm=shop&tbo=u&sa=X&ved=2ahUKEwi3n-j5pcPzAhXP
9/27/2022 3:13:20 AM • Intex Pool & Spa • Answered on Sep 27, 2022
2answers
I have an intex purespa that has stopped heating due to no water flow (code 90). When i turn on the filter button, the unit turns off within seconds. I turned the filter on and pumped air through the
I had a problem similar the water flow was good but still coded E90 after 9 sec. I put a magnet next to the water flow sensor. Finally after a long time trying to diagnosing the problem this finally worked I taped a magnet to it and put it he base back together. Been over a week now and it's still working! img_20220918_174610293_hdr-ke5itbqzl5loa3k5j5adjynu-d-6.jpg
9/26/2022 1:17:15 PM • Intex Pool & Spa • Answered on Sep 26, 2022
3answers
Intex hot tub (octagon 6 person) quit working, Everything is lit up on control panel. Where do I start?
unbolt control neck from base and check connection is tight and not corroded if good most likely control unit failed
8/31/2022 1:41:40 AM • Intex Pool & Spa • Answered on Aug 31, 2022
2answers
I have an Intex Pure Bubble Intex Pure Bubble Spa. The filters do not have any suction. Are they supposed to? If so how much? I do not feel anything.
For a test only, remove filters and see if you feel anything against the fitting? If nothing either 'Air Lock', keeping it from priming the pump. Or, bad pump! Secondly, are you still dealing with a problem? Use the comment link on this thread, and let the forum know if you are, if repaired, what did you do? Intex link... Support Intex
8/28/2022 4:03:49 AM • Intex Pool & Spa • Answered on Aug 28, 2022
The built in pump on my Intex mattress will not come on
test for circuit or motor failure
8/16/2022 12:17:41 PM • Intex Pool & Spa • Answered on Aug 16, 2022
Intex 10ft X 30in Easy Set Pool Package Logo
1 questions posted
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Intex Pool & Spa
  • Intex Pool & Spa
Most Popular Question
intex pure spa bubbles button not work
  • Pool & Spa
