20 Most Recent Dell Alienware M15x Gaming Notebook Questions & Answers
Looking at your last comment, it looks like you got it working??? Just an heads up, in the future, you might not want to put your laptop into sleep/standy mode while performing an update. If you lose power or have to do a hard shutdown you could corrupt the update and your PC might not boot back up.
Dell Alienware... | Answered on Jan 09, 2013
Get a can of compressed air and give a good blast to open ports and cooling fans, this may resolve the issue, if not the fan will need to be replaced. I do recommend the computer be taken apart down the road for good cleaning.
Dell Alienware... | Answered on Mar 15, 2012
try here this may help.http://steamcommunity.com/app/34030/discussions/0/540744474920987305/
Dell Alienware... | Answered on Mar 26, 2018
To install drivers for Dell Alienware laptops, go to Dell website under driver section, enter your laptop details asked here and you can get the compatible version of driver as per your computer configuration and operating system compatibility. Apart from operating system service provider also another option where you can find the driver for your Dell Alienware. However, sometimes you not find the compatible driver or downloading and installation is failed, at this moment you can get in touch with Dell Alienware Support number 1-844-395-2200 with toll-free calling to get online help of technicians and solve the issues of Alienware driver. 1 8443952200 Dell Alienware Tech Support Number for Gaming PC
Dell Alienware... | Answered on Jun 23, 2017
There is probably bad boot option, or HDD simply stopped.Try look for the HDD in BIOS...if its not there, then you have faulty HDD.
Dell Alienware... | Answered on Sep 16, 2015
  • All MyColors free themes and all Stardock freeware now have a registration built into them.
  • Here is how it works now:
  • Go to Impulse, and then to the store. Click on Desktop then choose to 'sort by price'.
  • You will see Diamond come up as a free download.
  • Click the free button and then on the next page select 'Add to Impulse'.
  • Impulse will ask you for your email if you do not have one,
  • or it should prompt you for the one you are logged in with.
  • Either way hit Register or enter your current email and hit register.
  • Impulse will then download Diamond for you while creating your Diamond registry.
  • You will find the free download under MyDesktop.
  • Upon successful completion an email containing download and
  • registration information will be sent to you via the address you have entered.
Dell Alienware... | Answered on Aug 11, 2015
Which administrator account are you talking about? The 'real' administrator or your normal "administrator group" account? If it's you normal account do you have another account with administrator privileges?
Rather than wait for answers I'll cover the above three possibilities. If it's something else I'll need more input.
1) If it's the real administrator, this is a fairly easy fix (that I had to do the other day because my OEM set a password for the account).
·Open Control Panel > User Accounts and select the option that allows you to change other accounts;
·Select the Administrator account;
·Turn off password required. Changing this option will not require a password.
2) If it's your own account but you have another account on the system with administrator privileges, the procedures above will work as well here.
3) If it's you own account and no other account has administrator privileges it will be much more complicated.
First, make a try at changing the account you are in to administrator. It's unlikely this will work and would be a major security hole, but it's worth a shot.
If that doesn't work, try booting to a command prompt and activating the real administrator. The procedures at this link attached with this post/answer, will walk you through booting to a command prompt. Once at the command prompt type the following two lines:
Net user administrator /active:yesNet user administratorp@ssw0rD Notes: 1) These two lines can be in any order; 2) "p@ssw0rD" is an example, type any password you ; and 3) The password line may not be needed in your case. I added it because my OEM set a password on my new computer. If they did on yours as well, you would have to boot back to a command prompt to change the password later so may as well do it now. You can always turn it off later.
Once you have the real administrator activated, boot back up and logon to the administrator account. Once there, use the procedure from "1)" above. this third possibility may not work, I've never actually had to try it this way, but it makes logical sense.
Good luck.
Windows 7 help and support forum
There is no such thing.
Contact Alienware, provide proof of ownership, and they may provide a backdoor password.
Dell Alienware... | Answered on Feb 12, 2015
Removing and replacing the memory battery should solve your problem if not let me know and I will be only to glad to help.
Barry
Dell Alienware... | Answered on Jan 24, 2015
If you go into control panel and Mouse and pointer settings you should be able to set it working properly again.
Barry
Sounds like your video card is either not in properly or the drivers and a miss match and need updating.
Barry
Have you tried removing the card and replacing it in a different slot which should get the computer to automatically find the card and the right drivers.
Barry
Usually on the door of the cd drive there is a very tiny hole. If you turn the laptop off. Then push a needle or thin bar in to the round slot The draw should release.
Hope this helps
Barry
Go to My Computer, select DVD ROM and right click. Select Eject.
Dell Alienware... | Answered on Jan 22, 2015
Actually most anything can cause them to do that. The helps that reduce those are a great Internet security, like Kaperski, a backup battery power supply, One of the main causes is low voltages. Your cpu cooling fan might be not functioning correctly or the system might be physically dirty or you might not be allowing air to get to the system, because of placement. There are many more reasons, so research the info I have sent you, maybe it will help.
Dell Alienware... | Answered on Dec 28, 2014
Hi judy, if you could let us know the make/model number we should be able to help!
Dell Alienware... | Answered on Nov 12, 2014
May have to take it in to get serviced but if it were me I would start taking it apart if the tray failed.
Let me know if the password prompt appears before windows boot or after windows boot. Also email me a picture of the password prompt screen along with the account holder name, place of purchase, email address and phone number to Kiran_kumar_a@dell.com . Then I can check and see what can be done.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Dell Alienware... | Answered on Oct 02, 2014
The scroll lock key will be located next to the F12 key (3rd button from F12 key. You may refer the below picture which might help:
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Dell Alienware... | Answered on Sep 27, 2014
Dell Alienware M15x Gaming Notebook Logo
3 questions posted
Clive
Clive
Alun Cox
View Most Popular
Alienware Dell
  • Alienware Dell
Most Popular Question
alienware m15x fan noise problem
  • Computers & Internet
