FixYa.com
Unitech MS210 Handheld
All Products > Unitech > Barcode Scanners
Problems with Unitech MS210 Handheld?
Search inside Unitech MS210 Handheld Knowledgebase
Troubleshooting and Support
Solved Problems for Unitech MS210 Handheld RSS Feed Post a New Problem
Problems with BHT scanner
when downloading data to BHT (new lookup) it starts to transfer some information and then stops, and 'File transfer,...
1 Solution
change region code on my apple mac
I have bought a DVD from Amazon and can't play it because I can't change the regio code on my computer - how do you do...
1 Solution
distributors requiring isbns when my CDs...
I have been seeking a distributor for my music products, initially three CDs. Because the CDs only have bar codes, is...
1 Solution
Optical Drive not working.
Hi! I use a Toshiba Tecra M5 notebook & it has MATSHITA DV RAM optical drive. This device is not working & the...
1 Solution
DS6708 symbol scanner freezes keyboard
Hi I was using this scanner for a few hours but we changed a few settings (by scanning barcodes from the manual). The...
1 Solution
barcode scanner for Verifone Omni 3750
Hello ! I'm trying to find the right barcode scanner for Verifone Omni 3750. Can you give me some tips? I'm looking...
1 Solution
Interested in Purchasing
I'm looking to buy a barcode scanner. Would anyone be able to recommend a good place to buy these, and a preferred...
3 Solutions
View All
Unsolved Support Problems
Unsolved Problems for Unitech MS210 Handheld RSS Feed Post a New Problem
Will not read barcode correctly
I replaced a damaged Unitech MS210 Handheld with the same model.... the old Handhelr would read the "10"...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeHandheld
InterfaceKeyboard Wedge · RS-232 · USB · Wand Emulation mode
ConnectivityWired
Optical
Light Sourcevisible laser diode (VLD) · Visible LED
Scan Rate45 Scans per second
Sensor Type2D CCD · Linear CCD
Technical Features
Special FeaturesPositive Beeper user feedback, Positive Led user feedback · Positive Beeper user feedback, Positive Led user feedback, Upgradable Flash Memory · Positive Led user feedback
CompatibilityPC, Mac
Decode CapabilityEAN-8, EAN-13, Code 39, Code 39 Full Ascii, UPC-A, Code 93, UPC-E, Code 128, CODABAR, Interleaved 2 of 5, MSI Plessey, Standard 2 of 5, UPC (E&A), Code 11, MSI, Chinese Postal, Code 32 · EAN-8, EAN-13, Code 39, Code 39 Full Ascii, UPC-A, Code 93, UPC-E, Code 128, CODABAR, Interleaved 2 of 5, MSI Plessey, Standard 2 of 5, Code 11, UCC EAN 128, Chinese Postal, Code 32 · EAN-8, EAN-13, Code 39, Code 39 Full Ascii, Code 93, Code 128, CODABAR, Interleaved 2 of 5, MSI Plessey, UPC (E&A), Code 11, UCC EAN 128, Code 32 · EAN-8, EAN-13, Code 39, Code 39 Full Ascii, UPC-A, Code 93, UPC-E, Code 128, CODABAR, Interleaved 2 of 5, MSI Plessey, Standard 2 of 5, Code 11, UCC EAN 128, MSI, Chinese Postal, Code 32
Environment protectionHumidity: 5% - 95% non condensing · Humidity: 20% - 95% non condensing
Dimensions
Depth3.15 in.
Height3.15 in.
Width.28 in.
Weight.28 lb.
Warranty
Warranty3 Years
Supported Models
ms210k, MS210KB, ms210l, ms210r, ms210-r25, MS210UB, ms210w
Unitech Contact Information
Main support number714 892 6225
Support FAX1 (714) 892 8605
Email supportinfo@unitech-na.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
