20 Most Recent Teac DV-M5000 DVD Player Questions & Answers
I have a Teac LCDV2655HD LCD TV and the DVD will
Sometimes there's a little pinhole on the cover where the DVD should exit. If you have one, straighten a paperclip and shove it into the hole. That should physically open the drawer/door.
2/18/2018 3:05:22 AM • Teac DV-M5000... • Answered on Feb 18, 2018
Disc is loaded we push
Unfortunately the problem is in the laser pickup assembly, overtime the laser becomes weaker until it can no longer track a DVD disc. One option is buy a disc cleaning kit and follow instructions to remove dirt from the lens, if this fails you are further ahead replacing the DVD player.
6/2/2011 2:46:32 AM • Teac DV-M5000... • Answered on Jun 02, 2011
My screen for teac lcd tv/DVD combo lcd1001m has gone dark, is there a way to fix this
If the screen for your TEAC LCD TV/DVD combo has gone dark, there are a few things you can try to fix it:
  1. Check the brightness settings: Make sure that the brightness setting on the TV is not turned all the way down. This can happen accidentally, and adjusting the setting may solve the problem.
  2. Check the power supply: If the TV is not receiving enough power, the screen may not light up properly. Make sure the power cord is plugged in securely and try using a different outlet.
  3. Check the connections: Check all the cables and connections between the TV and any other devices. Make sure they are plugged in correctly and that there are no loose connections.
  4. Reset the TV: Try resetting the TV to its factory settings. Consult the user manual for instructions on how to do this.
If none of these solutions work, there may be a hardware problem with the TV and it may need to be repaired or replaced.
2/26/2023 2:17:10 PM • Teac Televison &... • Answered on Feb 26, 2023
How do I tune my teac led/lcd digital tv model no:le32a321 without a remote
Here are some steps to tune a Teac LED/LCD digital TV without a remote:
  1. Find the TV's on-screen menu buttons on the TV itself (often located on the side or bottom of the TV)
  2. Use the arrow buttons to navigate to the channel setup or tuning menu
  3. Select "Auto Tuning" or "Channel Scan" and follow the on-screen instructions to scan for available channels
  4. If the TV has manual tuning option, select it and input the frequency, symbol rate, and other information for each channel you want to add manually.
  5. Once the tuning process is complete, the TV should display all the available channels. If you are unable to access the menu without a remote, consider using a universal remote that is compatible with your TV or obtaining a replacement remote from the manufacturer.
1/30/2023 1:44:29 PM • Teac Televison &... • Answered on Jan 30, 2023
How do i know if my digital optical setting is working on my Teac DV C-200?
Have you tried any other sound inputs Stacey?
6/13/2022 4:24:34 PM • Teac Televison &... • Answered on Jun 13, 2022
2answers
Teac 32television .nothing hooked up to itjust straight tv.model LET3296HD.GOES PERFECT FOR SHORT WHILE ,THEN SWITCHES ITSELF OFF, RED LIGHTTHEN BACK ON BUT GOES NO FURTHER THAN TEAC LOGO.? Regards
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview.]/
1/5/2022 8:47:11 AM • Teac Televison &... • Answered on Jan 05, 2022
Teac TV without remote control stuck on installation guide
Try a factory reboot
1/3/2022 11:11:23 PM • Teac Televison &... • Answered on Jan 03, 2022
2answers
I need the TEAC LEV24GD3FHD remote codes
gee have you ever used google and ask for code list
9/24/2021 12:55:29 PM • Teac Televison &... • Answered on Sep 24, 2021
The remote control UR-1314 for my TEAC A-R630 MKII amp. has stopped working and new batteries make no difference. Any ideas ? Thanks, John
A few things you can do is to make sure the remote window on the amp is free of debris. Looking at the amp upper left hand corner. When you press any button on the remote does the signal light flash and no response from the amp? If the signal light flashes on the remote and the sensor glass is clear and clean then it may either be the sensor in the amp or remote control that has gone bad. In that case only a certified dealer should repair your unit.
4/30/2021 2:08:25 PM • Teac Televison &... • Answered on Apr 30, 2021
I have an old TEAC power max 2000 system that doesn't work. When I plug in, it has the stand by led blinking red. I wonder if anyone can help me find the manual if can help me with this problem.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ https://homenol.blogspot.com/ https://elektrotricks.blogspot.com/ Blinking codes details to many popular brand TVs and other devices are given. If blinks continue without any pause, the main board is faulty. Search the sites by type in the brand name to your set, in its search box on the right side.
2/25/2021 2:57:07 PM • Teac Televison &... • Answered on Feb 25, 2021
2answers
Teac HDR9650TS DV Recorder does not power up, only displays "boot" what action do I take ?
Hi John, for what your Teac says, you are not completing the start sequence, I suggest you disconnect the Teac, for more than half an hour and after that time connect it and see if it turns on another possibility is that you need a Firmware update The Firmware can be updated through the USB port. Once you have downloaded the firmware from www.teac.com.au, place it on a USB stick. Please make sure that the USB memory does not have other files stored on it other than the required software file With the Teac HDR9650TS DV Recorder, unplugged, place the USB memory into the USB connector, then turn on the computer and wait for the power-up sequence to complete I send you the link to download the service manual I hope he manages to solve the problem Greetings Franco Dosil Hola John, por lo que comenta su Teac, no esta completando la secuencia de inicio, le sugiero desconectar el Teac, por mas de media hora y transcurrido ese tiempo re conectarlo y ver si enciende otra posibilidad es que necesite una actualizaci?n del Firmware El Firmware se puede actualizar a trav?s del puerto USB. Una vez que hayas descargado el firmware desde www.teac.com.au, col?quelo en una memoria USB. Por favor, aseg?rese de que la memoria USB no tiene otros archivos almacenados en ?l que no sea el archivo de software requerido Con el Teac HDR9650TS DV Recorder, desenchufado, coloque la memoria USB en el conector USB, luego prenda el equipo y espere que se complete la secuencia de encendido Le env?o el link para que descargue el manual de servicio Espero que logre resolver el problema Saludos Franco Dosil https://www.manualslib.com/manual/764925/Teac-Hdr9650ts.html
6/1/2020 5:26:56 AM • Teac Televison &... • Answered on Jun 01, 2020
I have a teac A5 smart led tv. Can I change channels without a remote?
Yes, you can change channels without the remote, if your TV source is OTA. Find the joystick button on the back of the TV; I believe it's on the left side as you look at the TV screen. Press the center of the button. You should see an information banner. Push the button up or down to scroll through the list of available channels. (If you press the center of the joystick twice, you will see the source list.) This is from the manual for the TEAC LE55A518UHD which I found here: https://www.teac.com.au/wp-content/uploads/2019/09/TEAC_A518_series_IM.pdf . I hope this helps. Cindy Wells
5/10/2020 6:06:14 PM • Teac Televison &... • Answered on May 10, 2020
Can I change channels on my Teac tv without using a remote?
https://www.youtube.com/watch?v=giUkBQRufGY use both volume buttons at the same time. Hey Josh Paradise, Most of the times it´s the menu button itself wich you can find on the tv. In order to press "ok" without a remote, I had to hold the "menu" button on the right side of the TV, and while holding press both volume buttons at the same time.https://www.ifixit.com/Answers/View/355860/How+do+I+select+OK+manually+without+a+remote https://www.ifixit.com/Answers/View/355860/How+do+I+select+OK+manually+without+a+remote
5/10/2020 10:40:05 AM • Teac Televison &... • Answered on May 10, 2020
2answers
Use dvd player without remote control
just able to watch the first show of my series dvd. is it somehow possible to watch the other shows of the dvd AmanStino Mouse Pad with Gel Wrist Pad grey9 0 7 8 AmanStino
3/12/2020 3:14:27 AM • Teac Televison &... • Answered on Mar 12, 2020
Teac TV remote I don't have but my TV is on installation guide, don't no how to exit
Hi Kylie, indicate model of your TV Teac that you are commenting, to be able to find the best possible solution I wait your answer Greetings Franco Dosil Hola Kylie, indica modelo de tu TV Teac que estas comentando, para poder encontrar la mejor soluci?n posible Espero tu respuesta Saludos Franco Dosil
8/12/2019 2:21:48 PM • Teac Televison &... • Answered on Aug 12, 2019
How to deal with message data base empty on teac tv
Data Base Empty means you don't have an aerial connected. Check that it is in the RF connector and not the coax port. common mistake
6/11/2019 11:34:25 PM • Teac Televison &... • Answered on Jun 11, 2019
Teac 22inch LED DVD/TV Model no. LEDV2216FV. 12v polarity was reversed. Power is not getting to the manual switch, the diode on the power board is okay and no obvious signs of damage. Thanks Tim
This is not a TEAC Model number for a 22" TV. TEAC only produced 2 LEDV 22 models. Either a LEDV2282FHD or LEDV22U83FHD. If there is no standby light then check the rocker switch located on the TV while powerpoint is on, if no result then there is a fault on the Power PCB
6/11/2019 11:33:03 PM • Teac Televison &... • Answered on Jun 11, 2019
Televison & Video Logo
3 questions posted
Top Teac Televison & Video Experts
deton8 von Splosion
Paul Katynski
Paul Katynski
Are you a Teac Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Teac Televison & Video
Most Popular Question
i have a teac lcdv2655hd lcd tv and the
  • Televison & Video
